Tomos A3 with 35/55 stator&flywheel with parmakit cdi
Matthew Fickett /
Ok gents. And ladies
Re: Tomos A3 with 35/55 stator&flywheel with parmakit cdi
Are we about to see the greatest show on earth ?
Matthew Fickett /
Are you kidding me....I wrote a whole thread and then I come to check in and it just says ok gents and ladies....hahaha
I've had that happen .
If you're writing a novel , do it in a place on your device that's secure , like Word Pad or Note Pad or the like . Then copy and paste it to the site of your choice .
Matthew Fickett /
And again. Wtf. Time to write on my device. I blame apple. Or trump. Or whoever else that has nothing to do with the site. Haha
Matthew Fickett /
Can someone tell me how to time this thing? Woodruff key removed to get it where it needs to be or...
I’m a noob to timing. I have a piston stop and a timing light
Matthew Fickett /
So I’m clear,
> 1. Piston stop find tdc
> 2. Mark flywheel and case anyplace at the same location.
> 3. Timing light and these marks should line up if timing is correct
> minus the 2.5mm btdc. (Treats gave me a 2.5mm for better temps.) so
> before tdc, measure over 2.5mm and when set correctly the marks should
> line up
> Am I getting this right? Lol
> What treats told me...
> “The box has a 7 degree timing curve so If you're timing your tomos to
> fire at 1.8mm BTDC at wide open throttle then you would want t o set is
> a 2.5mm BTDC. This will give you better over all temps and performance.
> -Dana“
Matthew Fickett /
I ended up slotting the stator more and getting it close to 2.5mm before tdc on idle. Waiting for my temp gauge to see what’s up. How far advanced is too far??? Lol I lost a little top end. If my temps are good when I get the gauge can I just keep advancing till I find the sweet spot?
To me that is too much. I like a lot less timing. I set it to 1.8mm BTDC.
You might be heat soaking the piston causing less power up top.
I put a mark on the flywheel and find where that mark fires. Then mark the case. Find where it is actually firing using a timing tool. Take flywheel off. Set the crank to the right position then line the marks up and reattach the flywheel. Then check again to make sure it is right.
Matthew Fickett /
The cdi has a curve of 7 degrees. They advised me of 2.5mm with the parmakit cdi to help with cooling. Again I don’t have a temp gauge yet so idk. I’m open for suggestions for sure.
I have heard of people setting it that high but I never had any good results with timing over 2mm BTC. I always set it at 1.8 with Tomos even with the Parmakit CDI. If your riding around town you won’t get into the upper RPMs where it will retard enough to cool it off.
I wouldn’t experiment anymore until you got a temp gauge. In the end you want a good ratio of power with temps below 400*f
