Ciao exhaust mounting
Hopefully my last question before my ciao gets stripped down and painted ..what does the spring attach to that hooks onto the loop on the exhaust? Do I have to attach a bolt using a nut onto the cylinder head studs?? Pics attached of exhaust and what I'm guessing are the bolts I need? Thanks again guys
Re: Ciao exhaust mounting
that 3rd mounts way off, just make sure your header clamp is on good, and that 13mm in the back is tight, and safety wire your baffle clamp to the exhaust so it dont rattle off n get run over.
Ye I did think that it's quite a distance away from anything I can attach it to ... are the bolts in pic what are meant to be used to attach to?
> attach to?
Those are exactly what their description states : Exhaust studs .
Meant to secure the exhaust header to the head .
Ok so what is the spring meant to attach to? One of the fins on head?
It could , but , apparently , it's not needed .
Ok cheers I'll see how it goes
Want to reply to this thread?
