how to remove motobecane cady connecting rod
Hi, need help removing the connecting rod, do I head up the part where I mark with an “X” and hammer out the connecting rod? Any suggestions would be greatly appreciateb. Thank you!
Re: how to remove motobecane cady connecting rod
never done a cady motor but thats what id do, hot hot hot then lightly tap.
I will give this a try, thank you!
derek from black pipes moped gang /
^^^ that and try using a deadblow hammer or a rubber mallet to avoid destroying the crank
kevin Smellaflange /
dead fall hammer down on a block of pine board...
the heat is @ about 200* degrees.
hot gloves...left & right
Thank you all very much for the great suggestions, I applied heat (hot) and hammered it gently and it separated like you have suggested ;-)
