Re: variator or belt ?
- Joe - /
If your using polini or malossi variator springs you may need to grind the spring a bit to get the cheeks to open more. Treats sells the cnc variator pulleys which look to be the same thing I’m making for my bikes.
https://www.treatland.tv/vespa-piaggio-CNC-d-steel-racing-driven-pulley-pla-p/cnc-vespa-pulley-plates.htm
