Re: Throttle Cable
P D /
> Mike M Wrote:
> don't forget to get some cable lube. made that mistake and had a sticky
> throttle. they also make these things that make it easier to lube cables
> without making a huge mess. got one of those too and it is awesome. just
> a little lube, don't use too much.
This what Mike's on about :
Cable lubber
I don't know why he says 'not too much lube' .
I always use enough to lube the whole cable , end to end . I like to see it run out the other end .
If you ever lube a Honda OEM cable , be sure to use a graphite based lube , as they have a plastic inner lining that can be destroyed using petroleum based lubes .
