Re: Throttle Cable
Mike M /
P D: that is exactly the tool i was talking about. when i said not to overdo it on the lube (i don't think you really can overdo it on lube usually) i was referring more to the fact that you don't have to use a ton to get the whole cable. i've used that tool and sprayed a few spritzes in the hole and was able to run the whole cable through and get it nice and slick. no need to go overboard.
