Wiring to start engine without hooking everything up
Its probably somewhere in the forums (but the search sucks).
Honda Hobbit.
I'd like to start it on the bench without hooking everything back up... and starting it with a drill.
What do you wire up to make this work?
Re: Wiring to start engine without hooking everything up
the coil n a ground, and the spark plug wire.
easy enough, thanks Pat.
