No Spark
Had spark and the bike started and ran but then just died with no spark. Snap decision HT coil, changed out for a good one and still no spark, my thought is its the condenser? can you test them without removing them?
This is on a 78 stock puch that I'm having the spark trouble with.
Re: No Spark
SOME BIKES lose spark when a taillight bulb or brakelight bulb burn out. Not kidding!
Re: No Spark
I don't think your tail light/brake light is the issue, I could be mistaken but I don't think the coil grounds through it on your bike. Have you filled the points?
Re: No Spark
New tail light, the real question is do I need to remove condenser to check it with my multimeter?
Re: No Spark
Moped Lar (OFMC) /
Clean points and check gap.
Re: No Spark
that was the ticket, started right up.
fouled spark plug/wet spark plug....is that too big of jet?
running a tecno pipe and everything is stock
#68 jet is in it
Re: No Spark
if you have a 14 bing 68 not toooo big, but a fouled plug...might be float height, leaky float needle, sticky float, sticky choke.
http://www.myronsmopeds.com/wp-content/uploads/2015/06/Info-Puch-Speed-Versions.jpg
Re: No Spark
Check the points. And make sure you are grounded to the scooter properly.
Re: No Spark
> properly.
Matt, it's a Puch moped...……………...don't degrade it by calling it the `S' word. LOL!
