Puch clutch ( I think ) issue
Having a problem with a Puch clutch ( I think it's the clutch at least ). Will need some help diagnosing though.
Pedal start works fine but when you let go of the clutch lever the engine stops, recently changed the oil in it so have a feeling this might be the cause of the problem as this never occurred before that.
Changed from 5w30 to ATF fluid aqm
Re: Puch clutch ( I think ) issue
Moped Lar (OFMC) /
One speed or two?
One, E50 not za50
It sounds like the motor isn't starting from your description.
This is true. It likely has nothing to do with the clutch.
When you're turning the bike over using the clutch it's firing but not running (or else it would keep running after you let go of the clutch). I'd check your spark, carb, and timing in that order
Motor starts, just doesn't want to stay started, when you let go of the clutch lever the engine dies again
