Low Compression/ Airleaks
Are there really other spots to check for air leaks than the carb, plug threads, exhaust, head gasket. Im running out of places to look.
Re: Low Compression/ Airleaks
Josiah Radebaugh /
Do you have low compression? Depending on the bike, you might have a stuck decompression. Or, buggered up ring.
I got a morini m01 engine. if I don't find anything ill probably sand the surfaces with 400 grit sandpaper
Moped Lar (OFMC) /
Flywheel side seal.(edited)
Josiah Radebaugh /
I'd do a higher grit
What is your compression?
I had about 96 lbs of compression. I didn't test it recently but im guessing its still in that range.
