Re: JB Welded Front Sproket Removal
Keep in mind that you need clearance between the sprocket and the case, some larger sprockets will require the case to be ground away for clearance. Or so I've heard. Just sold my only minarelli bike, I kept the stock 10 tooth front with a 44 or 45 in the back, did 35mph with 16 inch wheels on the stock lightly ported cylinder with a pipe. Keep in mind I'm 160lbs fully dressed.
With a cylinder kit you can afford taller gearing without losing much low end. But depending on swingarm clearance, it may make more sense to change the rear sprocket to a smaller one than the front to a larger one, to avoid grinding the case.
Seeing as you're replacing both sprockets anyway, I would check and see how much room you have, and report back. You'll probably want to go with somewhere around 10 x 42 gears, just a guess? Dont want to rev too high with a bushing crank if you have one. Keep it under 9k http://toolbox.martysgarage.info
Just my .2(edited)
  JB Welded Front Sproket RemovalTopic by: Anthony Lea Anthony Lea 05/07/19 08:51AM
  Re: JB Welded Front Sproket RemovalRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/07/19 09:13AM
  Re: JB Welded Front Sproket RemovalRe: Anthony Lea Anthony Lea 05/07/19 09:25AM
  Re: JB Welded Front Sproket RemovalRe: Dirty30 Dillon Dirty30 Dillon 05/07/19 09:49AM
  Re: JB Welded Front Sproket RemovalRe: Anthony Lea Anthony Lea 05/07/19 09:57AM
  Re: JB Welded Front Sproket RemovalRe: Anthony Lea Anthony Lea 05/07/19 02:10PM
  Re: JB Welded Front Sproket RemovalRe: Dirty30 Dillon Dirty30 Dillon 05/07/19 09:22AM
  Re: JB Welded Front Sproket RemovalRe: Anthony Lea Anthony Lea 05/07/19 09:27AM
  Re: JB Welded Front Sproket RemovalRe: cheetahchrome . cheetahchrome . 05/07/19 03:55PM
  Re: JB Welded Front Sproket RemovalRe: Anthony Lea Anthony Lea 05/07/19 04:09PM
  Re: JB Welded Front Sproket RemovalRe: cheetahchrome . cheetahchrome . 05/07/19 04:30PM
  Re: JB Welded Front Sproket RemovalRe: Anthony Lea Anthony Lea 05/07/19 05:22PM
  Re: JB Welded Front Sproket RemovalRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/07/19 05:33PM
  Re: JB Welded Front Sproket RemovalRe: pat splat pat splat 05/07/19 08:13PM
  Re: JB Welded Front Sproket RemovalRe: Richard Eberline Richard Eberline 05/07/19 08:54PM
  Re: JB Welded Front Sproket RemovalRe: Anthony Lea Anthony Lea 05/08/19 07:39AM
  Re: JB Welded Front Sproket RemovalRe: EH FCC of the QCB EH FCC of the QCB 05/08/19 06:15AM
  Re: JB Welded Front Sproket RemovalRe: Anthony Lea Anthony Lea 05/08/19 07:37AM
  Re: JB Welded Front Sproket RemovalRe: pat splat pat splat 05/08/19 08:17AM
  Re: JB Welded Front Sproket RemovalRe: Anthony Lea Anthony Lea 06/10/19 12:55AM
