Re: Problem with TrailTech temperature gauge
Aaron Blair /
Yes, but you would need access to a lab spectrum analyser...no need though..if you really want to hear the interference got to a second hand store and grab an am radio...I'd bet with it next to the points you won't find a station, just static that might modulate with rpm...
Excess rf is usually due to an A wide points gap....when Marconi invented radio transmission it had no antenna! The transmitter was a modulated high voltage spark gap! Guess what ur points are doing :) a new condenser might help as well.
Adjust ur points, should only need a screwdriver and something the correct size to shove in between whilst tightening...the gap should be listed here somwheres..but I just use cardboard from a case of beer, never had a problem...
  Problem with TrailTech temperature gaugeTopic by: Moped Newbie Moped Newbie 05/08/19 09:14PM
  Re: Problem with TrailTech temperature gaugeRe: spencerrrrr r spencerrrrr r 05/08/19 11:26PM
  Re: Problem with TrailTech temperature gaugeRe: * * * * 05/08/19 11:31PM
  Re: Problem with TrailTech temperature gaugeRe: Aaron Blair Aaron Blair 05/09/19 01:01AM
  Re: Problem with TrailTech temperature gaugeRe: Alex hernandez Alex hernandez 05/09/19 07:35AM
  Re: Problem with TrailTech temperature gaugeRe: Moped Newbie Moped Newbie 05/10/19 07:41AM
  Re: Problem with TrailTech temperature gaugeRe: Aaron Blair Aaron Blair 05/10/19 08:08AM
  Re: Problem with TrailTech temperature gaugeRe: Moped Newbie Moped Newbie 05/11/19 09:11AM
  Re: Problem with TrailTech temperature gaugeRe: Aaron Blair Aaron Blair 05/11/19 10:07AM
  Re: Problem with TrailTech temperature gaugeRe: * * * * 05/11/19 01:36PM
  Re: Problem with TrailTech temperature gaugeRe: Moped Newbie Moped Newbie 05/11/19 02:39PM
  Re: Problem with TrailTech temperature gaugeRe: P D P D 05/11/19 02:57PM
  Re: Problem with TrailTech temperature gaugeRe: Moped Newbie Moped Newbie 05/11/19 02:56PM
  Re: Problem with TrailTech temperature gaugeRe: Barry (Bob) Brown Barry (Bob) Brown 05/12/19 11:18PM
  Re: Problem with TrailTech temperature gaugeRe: Overpriced Parts Overpriced Parts 05/13/19 02:02AM
  Re: Problem with TrailTech temperature gaugeRe: Jason White Jason White 05/14/19 12:02AM
  Re: Problem with TrailTech temperature gaugeRe: Moped Newbie Moped Newbie 05/15/19 09:29AM
  Re: Problem with TrailTech temperature gaugeRe: Moped Newbie Moped Newbie 05/25/19 08:44AM
  Re: Problem with TrailTech temperature gaugeRe: Ashley Ackley Ashley Ackley 05/28/19 02:30PM
  Re: Problem with TrailTech temperature gaugeRe: EH FCC of the QCB EH FCC of the QCB 08/04/19 09:16PM
  Re: Problem with TrailTech temperature gaugeRe: EH FCC of the QCB EH FCC of the QCB 08/11/19 12:35PM
  Re: Problem with TrailTech temperature gaugeRe: Aaron Blair Aaron Blair 05/28/19 07:52PM
  Re: Problem with TrailTech temperature gaugeRe: Ungapped rings to bind them all Ungapped rings to bind them all 05/29/19 03:14PM
  Re: Problem with TrailTech temperature gaugeRe: * wormdirt * * wormdirt * 05/30/19 11:42AM
  Re: Problem with TrailTech temperature gaugeRe: Brandon - Brandon - 07/31/19 10:35PM
  Re: Problem with TrailTech temperature gaugeRe: Brandon - Brandon - 08/02/19 10:42PM
  Re: Problem with TrailTech temperature gaugeRe: William Johnson William Johnson 08/13/19 03:49PM
  Re: Problem with TrailTech temperature gaugeRe: Marc Friedman Marc Friedman 09/15/19 09:57AM
  Re: Problem with TrailTech temperature gaugeRe: Moped Newbie Moped Newbie 05/16/20 11:45PM
