Re: 1982 Honda express won’t start
Captain Janeway /
> Owen Sims Wrote:
> Yes, the stator area has oil inside of it and I just thought that it was
> supposed to be like that.
Bad seals give air leaks on these bikes too. I hope you have manual by this time. Note that seals on Left and Right sides are different sizes. You have to pull the kickstarter gear behind the variator to get at it, then pull with a 3 jaw puller. Make sure you put some kind of protection between the spike on it and the end of your crank, or you could split it (not kidding, I've seen a picture of it on here somewhere). People have different way of getting on the right side seals. most people just use some kind of pick to pull it. I'm using a paint can opener. Can get one free at the hardware store. Some of the techniques are on YouTube.
And yes, go ahead and change the rings. They're relatively cheap. If you can solve the problem with new rings it will save you swapping those seals (at least for now). As you can see, it's kind of a pain.
  1982 Honda express won’t startTopic by: Owen Sims Owen Sims 05/13/19 09:05PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/13/19 09:13PM
  Re: 1982 Honda express won’t startRe: Mike Kirn Mike Kirn 05/13/19 10:03PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 05/13/19 10:31PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/13/19 10:06PM
  Re: 1982 Honda express won’t startRe: Mike Kirn Mike Kirn 05/14/19 11:39AM
  Re: 1982 Honda express won’t startRe: JD Funair JD Funair 05/14/19 11:14AM
  Re: 1982 Honda express won’t startRe: Stephen Keller Stephen Keller 05/14/19 10:29PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/14/19 12:56PM
  Re: 1982 Honda express won’t startRe: P D P D 05/14/19 03:02PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/14/19 05:19PM
  Re: 1982 Honda express won’t startRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/15/19 08:58AM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 05/15/19 11:36AM
  Re: 1982 Honda express won’t startRe: Mike Kirn Mike Kirn 05/14/19 06:43PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/14/19 06:55PM
  Re: 1982 Honda express won’t startRe: Mike Kirn Mike Kirn 05/14/19 07:58PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/14/19 10:43PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/15/19 02:40PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/15/19 02:50PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 05/16/19 12:02AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/16/19 09:48PM
  Re: 1982 Honda express won’t startRe: Nash . Nash . 05/16/19 10:18PM
  Re: 1982 Honda express won’t startRe: Jeff Adams Jeff Adams 05/17/19 11:15AM
  Re: 1982 Honda express won’t startRe: Jeff Adams Jeff Adams 05/17/19 11:18AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/20/19 10:14PM
  Re: 1982 Honda express won’t startRe: P D P D 05/21/19 07:45AM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 05/21/19 10:01AM
  Re: 1982 Honda express won’t startRe: Charles Brady Charles Brady 08/10/19 08:40AM
  Re: 1982 Honda express won’t startRe: Aaron Blair Aaron Blair 05/21/19 09:15AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/21/19 09:12PM
  Re: 1982 Honda express won’t startRe: Mike Kirn Mike Kirn 05/21/19 11:04PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/21/19 11:07PM
  Re: 1982 Honda express won’t startRe: P D P D 05/22/19 07:12AM
  Re: 1982 Honda express won’t startRe: Mike Kirn Mike Kirn 05/22/19 07:39PM
  Re: 1982 Honda express won’t startRe: alex ganz alex ganz 05/22/19 10:47AM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 05/22/19 11:18AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/22/19 02:41PM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 05/22/19 03:10PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/22/19 03:51PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/23/19 09:21PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 05/24/19 12:27PM
  Re: 1982 Honda express won’t startRe: P D P D 05/24/19 12:45PM
  Re: 1982 Honda express won’t startRe: Ryan . Ryan . 07/04/19 02:30PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/24/19 05:58PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/24/19 09:22PM
  Re: 1982 Honda express won’t startRe: P D P D 05/24/19 10:21PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 05/25/19 11:16AM
  Re: 1982 Honda express won’t startRe: P D P D 05/25/19 02:35PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/24/19 11:51PM
  Re: 1982 Honda express won’t startRe: Aaron Blair Aaron Blair 05/25/19 02:21AM
  Re: 1982 Honda express won’t startRe: P D P D 05/25/19 07:26AM
  Re: 1982 Honda express won’t startRe: Mike Kirn Mike Kirn 05/25/19 09:05AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/25/19 09:35AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/25/19 11:34AM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 05/25/19 02:56PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/25/19 06:25PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/26/19 02:19PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/28/19 10:00AM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 05/28/19 10:34AM
  Re: 1982 Honda express won’t startRe: Stephen Keller Stephen Keller 06/10/19 12:44AM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 05/28/19 02:01PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/05/19 08:41PM
  Re: 1982 Honda express won’t startRe: Seth B Seth B 06/10/19 12:05PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/08/19 01:35PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/09/19 03:19PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 06/10/19 12:13AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/10/19 10:54AM
  Re: 1982 Honda express won’t startRe: Keno Rojas Keno Rojas 06/11/19 03:22AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/11/19 10:01AM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 06/11/19 10:50AM
  Re: 1982 Honda express won’t startRe: P D P D 06/11/19 11:13AM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 06/11/19 07:09PM
  Re: 1982 Honda express won’t startRe: P D P D 06/12/19 07:45AM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 06/11/19 08:44PM
  Re: 1982 Honda express won’t startRe: P D P D 06/12/19 07:40AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/13/19 08:19PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/14/19 08:45PM
  Re: 1982 Honda express won’t startRe: Mike Kirn Mike Kirn 06/26/19 03:52PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 06/14/19 11:30PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/15/19 12:02AM
  Re: 1982 Honda express won’t startRe: P D P D 06/15/19 08:36AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/25/19 09:29PM
  Re: 1982 Honda express won’t startRe: P D P D 06/26/19 09:26AM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 06/26/19 01:04PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/26/19 02:35PM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 06/26/19 03:48PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/26/19 04:19PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 06/28/19 09:35AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/29/19 10:41AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/29/19 04:11PM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 06/29/19 07:06PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/29/19 07:24PM
  Re: 1982 Honda express won’t startRe: Aaron Blair Aaron Blair 06/29/19 08:51PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/29/19 09:48PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 06/29/19 11:45PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/03/19 07:29PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 07/03/19 10:45PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/03/19 11:01PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/30/19 08:37AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/03/19 08:04PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/03/19 10:59PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 07/04/19 05:09PM
  Re: 1982 Honda express won’t startRe: Ryan . Ryan . 07/04/19 09:33PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/04/19 11:20PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/04/19 09:15AM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 07/04/19 01:17PM
  Re: 1982 Honda express won’t startRe: P D P D 07/04/19 01:41PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/04/19 09:19AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/04/19 11:08AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/04/19 11:11AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/04/19 02:07PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/04/19 02:41PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/04/19 07:08PM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 07/05/19 12:17AM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/05/19 12:31AM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/05/19 01:25AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/05/19 11:30AM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/05/19 11:43AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/05/19 11:56AM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/05/19 12:09PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/05/19 12:17PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/05/19 12:32PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/05/19 12:34PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/05/19 12:45PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/05/19 01:14PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/05/19 01:21PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/05/19 01:23PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/05/19 01:35PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/05/19 02:52PM
  Re: 1982 Honda express won’t startRe: Shawn Manthey Shawn Manthey 07/05/19 04:27PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/05/19 01:36PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/05/19 03:59PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/05/19 05:44PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/05/19 06:00PM
  Re: 1982 Honda express won’t startRe: Shawn Manthey Shawn Manthey 07/05/19 07:08PM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 07/06/19 12:49AM
  Re: 1982 Honda express won’t startRe: Ryan . Ryan . 07/05/19 05:56PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 07/06/19 12:28AM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/06/19 11:36AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/06/19 11:12PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/07/19 12:55AM
  Re: 1982 Honda express won’t startRe: Shawn Manthey Shawn Manthey 07/07/19 03:03PM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 07/07/19 01:08AM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/07/19 01:10AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/07/19 03:31PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 07/07/19 11:39PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/07/19 04:41PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/08/19 09:33AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/08/19 11:33PM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 07/09/19 12:24AM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 07/09/19 09:53AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/09/19 09:19AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/14/19 10:14AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/14/19 05:45PM
  Re: 1982 Honda express won’t startRe: P D P D 07/14/19 05:57PM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 07/14/19 06:21PM
  Re: 1982 Honda express won’t startRe: P D P D 07/14/19 07:24PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/15/19 12:09AM
  Re: 1982 Honda express won’t startRe: Ryan . Ryan . 07/15/19 09:21AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/14/19 06:19PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/15/19 08:28AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/15/19 10:24AM
  Re: 1982 Honda express won’t startRe: Ryan . Ryan . 07/15/19 10:36AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/15/19 06:23PM
  Re: 1982 Honda express won’t startRe: Ryan . Ryan . 07/15/19 06:40PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/15/19 06:48PM
  Re: 1982 Honda express won’t startRe: Ryan . Ryan . 07/15/19 06:56PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/15/19 07:33PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/15/19 07:54PM
  Re: 1982 Honda express won’t startRe: Ryan . Ryan . 07/15/19 08:03PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/15/19 08:16PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/15/19 08:30PM
  Re: 1982 Honda express won’t startRe: Ryan . Ryan . 07/15/19 08:35PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/18/19 12:44PM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 07/18/19 02:40PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/18/19 04:45PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/18/19 07:59PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/19/19 09:54PM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 07/20/19 12:15PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/21/19 04:58AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/19/19 10:38PM
  Re: 1982 Honda express won’t startRe: Shawn Manthey Shawn Manthey 07/19/19 11:45PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/19/19 11:48PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 07/22/19 08:09PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/22/19 06:13PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/22/19 08:16PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/22/19 08:30PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/22/19 09:11PM
