Re: 1982 Honda express won’t start
live ɘvil /
> Jack Rutherford Wrote:
> Dude, you've got too much going on here.
> 1. Slide in correctly?
> 2. Did you try to adjust the carb air/fuel screw and throttle stop
> screw? Could be your throttle stop screw is turned too far in.
> 3. Auto choke functioning properly?
> 4. All your auto choke hoses in good shape and correctly installed? No
> open ports?
> 5. Test for air leaks with carb cleaner at all joints? Head to
> cylinder, cylinder to case, intake to carb, carb chamber cap, intake to
> case?
> 6. coils no longer oil soaked?
> Did we ever determine what the oil was like that was in your
> stator/flywheel? If that was straight, unadulterated oil then I doubt
> it came from a bad seal. More likely leaked out of the oil reservoir
> and somehow got inside your flywheel/stator. Are you missing the rubber
> plug that goes in the timing port?
Agreed. Check the simple stuff first. But if that stator compartment smells of gas then thats a problem.
Also, MORE PICS OF THE AREA WITH THE CRACK IN THE ENGINE CASE !!!! IT COULD BE JUNK!!
  1982 Honda express won’t startTopic by: Owen Sims Owen Sims 05/13/19 09:05PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/13/19 09:13PM
  Re: 1982 Honda express won’t startRe: Mike Kirn Mike Kirn 05/13/19 10:03PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 05/13/19 10:31PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/13/19 10:06PM
  Re: 1982 Honda express won’t startRe: Mike Kirn Mike Kirn 05/14/19 11:39AM
  Re: 1982 Honda express won’t startRe: JD Funair JD Funair 05/14/19 11:14AM
  Re: 1982 Honda express won’t startRe: Stephen Keller Stephen Keller 05/14/19 10:29PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/14/19 12:56PM
  Re: 1982 Honda express won’t startRe: P D P D 05/14/19 03:02PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/14/19 05:19PM
  Re: 1982 Honda express won’t startRe: Moped Lar (OFMC) Moped Lar (OFMC) 05/15/19 08:58AM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 05/15/19 11:36AM
  Re: 1982 Honda express won’t startRe: Mike Kirn Mike Kirn 05/14/19 06:43PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/14/19 06:55PM
  Re: 1982 Honda express won’t startRe: Mike Kirn Mike Kirn 05/14/19 07:58PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/14/19 10:43PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/15/19 02:40PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/15/19 02:50PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 05/16/19 12:02AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/16/19 09:48PM
  Re: 1982 Honda express won’t startRe: Nash . Nash . 05/16/19 10:18PM
  Re: 1982 Honda express won’t startRe: Jeff Adams Jeff Adams 05/17/19 11:15AM
  Re: 1982 Honda express won’t startRe: Jeff Adams Jeff Adams 05/17/19 11:18AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/20/19 10:14PM
  Re: 1982 Honda express won’t startRe: P D P D 05/21/19 07:45AM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 05/21/19 10:01AM
  Re: 1982 Honda express won’t startRe: Charles Brady Charles Brady 08/10/19 08:40AM
  Re: 1982 Honda express won’t startRe: Aaron Blair Aaron Blair 05/21/19 09:15AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/21/19 09:12PM
  Re: 1982 Honda express won’t startRe: Mike Kirn Mike Kirn 05/21/19 11:04PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/21/19 11:07PM
  Re: 1982 Honda express won’t startRe: P D P D 05/22/19 07:12AM
  Re: 1982 Honda express won’t startRe: Mike Kirn Mike Kirn 05/22/19 07:39PM
  Re: 1982 Honda express won’t startRe: alex ganz alex ganz 05/22/19 10:47AM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 05/22/19 11:18AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/22/19 02:41PM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 05/22/19 03:10PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/22/19 03:51PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/23/19 09:21PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 05/24/19 12:27PM
  Re: 1982 Honda express won’t startRe: P D P D 05/24/19 12:45PM
  Re: 1982 Honda express won’t startRe: Ryan . Ryan . 07/04/19 02:30PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/24/19 05:58PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/24/19 09:22PM
  Re: 1982 Honda express won’t startRe: P D P D 05/24/19 10:21PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 05/25/19 11:16AM
  Re: 1982 Honda express won’t startRe: P D P D 05/25/19 02:35PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/24/19 11:51PM
  Re: 1982 Honda express won’t startRe: Aaron Blair Aaron Blair 05/25/19 02:21AM
  Re: 1982 Honda express won’t startRe: P D P D 05/25/19 07:26AM
  Re: 1982 Honda express won’t startRe: Mike Kirn Mike Kirn 05/25/19 09:05AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/25/19 09:35AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/25/19 11:34AM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 05/25/19 02:56PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/25/19 06:25PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/26/19 02:19PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 05/28/19 10:00AM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 05/28/19 10:34AM
  Re: 1982 Honda express won’t startRe: Stephen Keller Stephen Keller 06/10/19 12:44AM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 05/28/19 02:01PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/05/19 08:41PM
  Re: 1982 Honda express won’t startRe: Seth B Seth B 06/10/19 12:05PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/08/19 01:35PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/09/19 03:19PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 06/10/19 12:13AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/10/19 10:54AM
  Re: 1982 Honda express won’t startRe: Keno Rojas Keno Rojas 06/11/19 03:22AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/11/19 10:01AM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 06/11/19 10:50AM
  Re: 1982 Honda express won’t startRe: P D P D 06/11/19 11:13AM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 06/11/19 07:09PM
  Re: 1982 Honda express won’t startRe: P D P D 06/12/19 07:45AM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 06/11/19 08:44PM
  Re: 1982 Honda express won’t startRe: P D P D 06/12/19 07:40AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/13/19 08:19PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/14/19 08:45PM
  Re: 1982 Honda express won’t startRe: Mike Kirn Mike Kirn 06/26/19 03:52PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 06/14/19 11:30PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/15/19 12:02AM
  Re: 1982 Honda express won’t startRe: P D P D 06/15/19 08:36AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/25/19 09:29PM
  Re: 1982 Honda express won’t startRe: P D P D 06/26/19 09:26AM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 06/26/19 01:04PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/26/19 02:35PM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 06/26/19 03:48PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/26/19 04:19PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 06/28/19 09:35AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/29/19 10:41AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/29/19 04:11PM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 06/29/19 07:06PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/29/19 07:24PM
  Re: 1982 Honda express won’t startRe: Aaron Blair Aaron Blair 06/29/19 08:51PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/29/19 09:48PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 06/29/19 11:45PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/03/19 07:29PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 07/03/19 10:45PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/03/19 11:01PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 06/30/19 08:37AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/03/19 08:04PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/03/19 10:59PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 07/04/19 05:09PM
  Re: 1982 Honda express won’t startRe: Ryan . Ryan . 07/04/19 09:33PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/04/19 11:20PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/04/19 09:15AM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 07/04/19 01:17PM
  Re: 1982 Honda express won’t startRe: P D P D 07/04/19 01:41PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/04/19 09:19AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/04/19 11:08AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/04/19 11:11AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/04/19 02:07PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/04/19 02:41PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/04/19 07:08PM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 07/05/19 12:17AM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/05/19 12:31AM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/05/19 01:25AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/05/19 11:30AM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/05/19 11:43AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/05/19 11:56AM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/05/19 12:09PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/05/19 12:17PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/05/19 12:32PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/05/19 12:34PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/05/19 12:45PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/05/19 01:14PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/05/19 01:21PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/05/19 01:23PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/05/19 01:35PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/05/19 02:52PM
  Re: 1982 Honda express won’t startRe: Shawn Manthey Shawn Manthey 07/05/19 04:27PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/05/19 01:36PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/05/19 03:59PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/05/19 05:44PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/05/19 06:00PM
  Re: 1982 Honda express won’t startRe: Shawn Manthey Shawn Manthey 07/05/19 07:08PM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 07/06/19 12:49AM
  Re: 1982 Honda express won’t startRe: Ryan . Ryan . 07/05/19 05:56PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 07/06/19 12:28AM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/06/19 11:36AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/06/19 11:12PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/07/19 12:55AM
  Re: 1982 Honda express won’t startRe: Shawn Manthey Shawn Manthey 07/07/19 03:03PM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 07/07/19 01:08AM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/07/19 01:10AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/07/19 03:31PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 07/07/19 11:39PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/07/19 04:41PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/08/19 09:33AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/08/19 11:33PM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 07/09/19 12:24AM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 07/09/19 09:53AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/09/19 09:19AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/14/19 10:14AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/14/19 05:45PM
  Re: 1982 Honda express won’t startRe: P D P D 07/14/19 05:57PM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 07/14/19 06:21PM
  Re: 1982 Honda express won’t startRe: P D P D 07/14/19 07:24PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/15/19 12:09AM
  Re: 1982 Honda express won’t startRe: Ryan . Ryan . 07/15/19 09:21AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/14/19 06:19PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/15/19 08:28AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/15/19 10:24AM
  Re: 1982 Honda express won’t startRe: Ryan . Ryan . 07/15/19 10:36AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/15/19 06:23PM
  Re: 1982 Honda express won’t startRe: Ryan . Ryan . 07/15/19 06:40PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/15/19 06:48PM
  Re: 1982 Honda express won’t startRe: Ryan . Ryan . 07/15/19 06:56PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/15/19 07:33PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/15/19 07:54PM
  Re: 1982 Honda express won’t startRe: Ryan . Ryan . 07/15/19 08:03PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/15/19 08:16PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/15/19 08:30PM
  Re: 1982 Honda express won’t startRe: Ryan . Ryan . 07/15/19 08:35PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/18/19 12:44PM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 07/18/19 02:40PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/18/19 04:45PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/18/19 07:59PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/19/19 09:54PM
  Re: 1982 Honda express won’t startRe: Captain Janeway Captain Janeway 07/20/19 12:15PM
  Re: 1982 Honda express won’t startRe: live ɘvil live ɘvil 07/21/19 04:58AM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/19/19 10:38PM
  Re: 1982 Honda express won’t startRe: Shawn Manthey Shawn Manthey 07/19/19 11:45PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/19/19 11:48PM
  Re: 1982 Honda express won’t startRe: Jack Rutherford Jack Rutherford 07/22/19 08:09PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/22/19 06:13PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/22/19 08:16PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/22/19 08:30PM
  Re: 1982 Honda express won’t startRe: Owen Sims Owen Sims 07/22/19 09:11PM
