Re: 1982 Honda express won’t start
Yes but it is pretty quick to take it apart
Most likely the crank seal is bad and thats where all the oil came from. Stick your nose in there and smell it.
Okay
At some point you'll be needing this too.
NU50 service manual(edited)
TAKE MORE PICS OF THIS AREA!
Preferably from above.
I will. Also can a crank seal cause low compression
Hell yes.
Okay
Where is the best place to buy one and should I get anything else for it that could be causing this problem?
I never worked on one of those but I was able to get seals from a local bearing shop for my NC50. You're in Kokomo so that shouldn't be a problem. Would be best to take the removed seal in person to a bearing shop. Oil resistant double lip seal. There are three sets of digits on all seals that represent I.d./o.d./thickness but I dont remember the order.
Hell it may take the same seal as a regular express
Treats may have them and youre gonna need a flywheel puller too. Do you have a band clamp to hold flywheel?(edited)
No
Shawn Manthey /
Treatland has the seals, I just got some about a week ago. They have a sale currently too. Left and right seals are different just so you know
I only found the left crank seal
A crank seal leak will not show a low reading on a compression gauge when tested at the spark plug. A few other things will though and all of those point to the wrong tester or testing procedure with exception to actual low compression.
All three of these are right side with measurements. Get the O.E.M. $6 one
Call a Honda shop and see if they are still available. 1982 NU50.
Shawn Manthey /
Left side seal measurements are 20x31x7. Right side seal measurements are 15x25.5x7
Jack Rutherford /
Dude, you've got too much going on here.
1. Slide in correctly?
2. Did you try to adjust the carb air/fuel screw and throttle stop screw? Could be your throttle stop screw is turned too far in.
3. Auto choke functioning properly?
4. All your auto choke hoses in good shape and correctly installed? No open ports?
5. Test for air leaks with carb cleaner at all joints? Head to cylinder, cylinder to case, intake to carb, carb chamber cap, intake to case?
6. coils no longer oil soaked?
Did we ever determine what the oil was like that was in your stator/flywheel? If that was straight, unadulterated oil then I doubt it came from a bad seal. More likely leaked out of the oil reservoir and somehow got inside your flywheel/stator. Are you missing the rubber plug that goes in the timing port?(edited)
> open ports?
> case?
Agreed. Check the simple stuff first. But if that stator compartment smells of gas then thats a problem.
Also, MORE PICS OF THE AREA WITH THE CRACK IN THE ENGINE CASE !!!! IT COULD BE JUNK!!
I got pictures of the crack
Thats a casting mark.
The case is fine.
Whats that magneto smell like??(edited)
Captain Janeway /
From these angles I don't see a crack either
What looked like a crack was a high spot, flashing, casting mark....
(edited)
Shawn Manthey /
You could always shoot some brake keen or starting fluid on that area and see if it makes a difference in running.
I feel like the auto choke doesn’t work because when ever you turn a choke on it revs it up but eventually will kill the engine
How do you know if the auto choke works?
Jack Rutherford /
It's an automatic choke so it turns on automatically, so to speak, when the engine is cold. Generally, it's working if your bike starts up when the engine is cold.
Well I probably shouldn’t have taken it apart
I have been reading old Honda urban express posts and am going to get a new fuel petcock for this, I found some but I don’t know if they would be reliable or just junk. Also where would I get a gasket for the automatic choke?
Captain Janeway /
> automatic choke?
Decent ones seem to be a pain to find in my experience. Make sure you get right size (16x1.5) and at minimum make sure it's held together with screws not rivets (they see to be better quality but a lot are crap regardless). I've had crappy luck with Savoir. The two I've bought have leaked.
Is your petcock leaking? If not I'd leave the stock on. They're better quality.
Just carefully screw the autochoke back together. Like jack said, if the bikes starting it's probably not the problem. I've not had an issue with them after 5 bikes
