Yes the petcock drips gas
Re: 1982 Honda express won’t start
> Owen Sims Wrote:
> I have been reading old Honda urban express posts and am going to get a
> new fuel petcock for this, I found some but I don’t know if they would
> be reliable or just junk. Also where would I get a gasket for the
> automatic choke?
probably have to cut your own gasket
I got the auto choke gasket back on
Find the manual and read .
https://drive.google.com/drive/folders/14rEwN0boHBqOTA1ZTgCZpWqTs88C3FEQ
I put my jump box on that wire with the fuse and the green wire and the turn signals work and the back light works but the front light does not work so could that be the no spark issue
This. Great info and plenty of pictures.
You now have two of these and still have not read up on the wiring? Did you compare it to the other one? Be careful you dont fry something with the jump box.
I was looking at the other one but the wires are bundled together inside the frame
Jump the two black and red wires together for spark. The lighting and ignition are ENTIRELY separate systems with the exception of the ignition switch. The headlight only works when the engine is running.
The two black on negative and two red on positive?
No the black with red stripe. The battery connector has an ignition jumper that prevents running if the battery is unplugged. It is not powered by the battery, just simply a disconnect safety feature to keep you from blowing the headlight by running the bike without a battery. Your connector has been cut off.
Can I still jump the wires to get spark? Because you said the connector has been cut off
Dude that is exactly what I said..
I’m sorry I sound like a idiot but are you saying I can’t see if there is spark without the connector?
I'm saying you can't see if there's spark without those two wires being one man. Factory they require the battery to be connected to JUMP THEM TOGETHER. Just twist them together. They are the same wire, same. It just runs into and then out of the plug so that the ignition power is broken if the battery is pulled. I can't say it any clearer.
I tried jumping all the wires different ways but I am still not sure what you meant when you said jump the two black and red wires together for spark and which wire doesn’t have the connector
The whole battery connector is missing man, you did fine. You have other spark issues. If it runs though you are going to blow the lights.
I still dont have spark So could it be the coil or is it electrical
There's at least a battery connector in that harness..
I got spark. It was the Cdi
Assuming your battery has the little connecting bolts, just crimp a connector to the end of the wire and screw it on that way. Worse comes to worse, I guess you could wiggle in the wire and squish it down with the nut, but I wouldn't necessarily count on it holding.
Still have t figured out the oil problem on the black one. But I got a battery for the silver one and started and like usual it was idling high so I lowered the idle screw and it was good for a little bit and now it won’t stay running and won’t go full speed on the stand
Oil pushing from where?? The pump with no hose on it? One of the hoses? All of the hoses. The tank??
Be more specific.
It’s in the last picture I posted. The line from the oil tank to the oil pump ( I think that’s what it is)
You could just premix your fuel. Little peace of mind.
