Mb5 master cylinder.
Does anyone know if an after market matter cylinder that would work on an MB5 and use the existing lines?
Re: Mb5 master cylinder.
Richard Eberline /
I have 3 that I cleaned and rebuilt. You have to do the reservoir, also. can buy parts on the web.
The master cylinder and reservoir are a single unit, in this case.
Any master cylinder should work in theory, it doesn't have to be for an MB5.
Do you have your M/C disassembled? If so measure the diameter of the bore. What is the bore diameter (10, 11, 12 or 13mm)? Another M/C of the same bore size will almost always work. Online
