woodruff key size on a V1
Richard Eberline /
I think its 3 x 3 x 9mm
Re: woodruff key size on a V1
Overpriced Parts /
You do not need the key just line it up perfectly and tighten it down very tight
Richard Eberline /
not for me, Ken.
And seeing as its probably on one of my engines, not for me either, Ken.
Dumb question, can't you remove a flywheel and woodruff key from one of the other 5 engines of mine and use the micrometer?
When I had a local guy get engine #8 running, he ended up going the the local Ace Hardware, getting a SAE woodruff key, and grinding it down to fit.
Josiah Radebaugh /
^^^^ I've been doing that with thing including V1 and Vespa clutchs. For a V1 the hardware keys are too long and a little too tall
You can buy a lifetime supply here.
