Cylinder Head Stripped
My spark plug won't go in past where it's at in the picture below. Not sure if I can rethread this or if I should get a new head.
Re: Cylinder Head Stripped
OG Crazy Wayne /
Yes replace both of them
If heads are readily available , I'd just replace it .
If not , tap it . You may have to use a bigger threaded plug .
You could also get a thread repair kit and stick with the 'standard' plug .
not sure about the fin, braze maybe. the plug hole is easy to retap and do an insert.
save a thread, 14 x 1.25 theres short med and long
The instructions are on YouTube.
