Keep Calm and Crank on? Stripped crank
Francois Labat /
Hey yall.
Been moving along on my build. I bought this crank here.Budget Crank
Got the whole motor put together with CDI etc. I tried using this nut and it didn't work.
Moby Reverse Nut
I was told the crank thread was right hand so bought this nutty .
When I had used the reverse i lightly buggered up the threads. Just by trying to put it on my hand. Then I tried to thread on the new proper nut and decided to start 1-2 threads and clean them up by cranking the nut on with a wrench...
I KNOW. This isn't my first nut. Anyways, it messed up the new nut and threads. I bought a thread file, fixed the thread and today I was able to hand thread the nut onto the threads maybe 1-4 threads. Then it got tight and I decided to use my little impact to get it on. I figure it would "clean up" the nut.
WRONG. It was a gamble I know but it got jammed and DESTROYED my crank shaft. I've stepped off the edge of the bridge, and am now debating if I order a new nut and use what thread is left. Will I have enough thread???
I've dealt with thousands of nuts and bolts. The damn work frustration pushed me to force this and was the wronggggg nut to mess with.
Re: Keep Calm and Crank on? Stripped crank
I'm a gambling man also. I'd cut off the messed up tip, make sure the threads are nice and clean, add a little oil to the crank and put a new nut on it.
Nut up and run it
Dirty30 Dillon /
Buy budget and get budget results I guess.
Sounds more like miscalculation than budget , to me .
Maybe try to cut new threads?
I'd fix the threads , get the right nut and run it .
Overpriced Parts /
> nut on it.
You got it right
Cut the bad tip/end off and make it nice
Would using a tap and die work here? I did something similar when I used a metal hammer to hit the crank to split the cases (after heating them up). Threads are bent inwards and I don't want to buy a new crank and take the whole this apart.
For the OP - either buy a new crank or cut off the part of the crank with the bad threads and clean it up. You should be using this nut on the magneto side, https://www.treatland.tv/mbk-flywheel-reverse-flywheel-nut-11mmx-1mm-p/mbk-flywheel-reverse-nut-11x1.htm.
Francois Labat /
Yes, it was not a budget crank problem. It was an emotional and frustration problem lol. Next time I'll punt a cabbage or something, not work on my moped instead.
The thread is beyond repair, that's for sure. I will clean it so that it doesn't interfere with the new nut I'll be ordering.
Thanks y'all. This is like my free counseling when moped pisses me off.
looks fine, use a metal file to taper n a new nut.
Yeah, and keep the impact gun away from yer moped. Less chance of a booboo.
I've got an engine with a flywheel that's been held on by maybe one thread, crank snout is broken, for the last three or four years.
I had to replace the points over the winter and thought that was it, I'd have to finally replace the crank but I got the flywheel back on solidly.
Lots of thread locker on that nut.
Get a thread file and straight the lead in to the remaining threads, put a new nut on, fortunately it is a taper shaft so the flywheel does not need a lot of torque to grip.
If you feel it still is not trustable then drill and tap the snout of the crank for a M6 bolt and throw in a goodly machine screw as a safety lock.
♣Slew Foot♣ /
You get a tool called a thread chaser and it clamps on and it's like a nut basically you could take a die and cut it and then put it back together with a set of screws and then work it off with a huge wrench and a breaker bar
-Summerai - Shong /
I've grinded down all the threads before and re-tapped/cut to the next thread size down on a spindle. You could do the same in this scenario.
Want to reply to this thread?
