Puch Maxi tranny leak
I've got a 1986 Puch Maxi Sport LS 2 speed that has a fairly steady leak from the gear box seam and plug area. Anyone have experience with this?I am ordering a new top plug so hopefully that will solve half the issue.
Re: Puch Maxi tranny leak
Yes. Take some pictures. You need new gaskets unless there is a visible crack in you engine cases.
Moped Lar (OFMC) /
Did you overfill it? You just add atf until it comes out the weep hole, not the fill plug.
Here are some photos of the leaks...
Chöschi21 C.K. /
These Engines like to Leak out of the Side Transmission Cover, that's probably your problem.
Looks likely Clutch cover gasket needs replaced and those are specific to that black cover 86 za50 engine, you need to email Doscycle to get the correct one for that year for old years silver face za50 clutch cover ones are different
Clean the oil off and apply talc or baby powder from the fill plug around and down .
Then run it until you see where the oil is coming from .
That will tell you what needs ...
Want to reply to this thread?
