Re: '78 vespa bravo new carb still wont idle
Brit Wilkens /
Bolt leaking grease is pretty common cuz it's real easy to over-tighten. Time to pull off your wheel, pull the hub and you're gonna need to silicon seal the inside where the bolt holes leaks. Just do em both and they should hold for a good while.
  '78 vespa bravo new carb still wont idleTopic by: Colin Onda Colin Onda 06/23/19 10:54AM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/23/19 03:04PM
  Re: '78 vespa bravo new carb still wont idleRe: Stephen Simmons Stephen Simmons 06/23/19 03:46PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/23/19 04:57PM
  Re: '78 vespa bravo new carb still wont idleRe: Stephen Simmons Stephen Simmons 06/23/19 05:09PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/23/19 05:25PM
  Re: '78 vespa bravo new carb still wont idleRe: pat splat pat splat 06/23/19 05:42PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/23/19 06:28PM
  Re: '78 vespa bravo new carb still wont idleRe: Stephen Simmons Stephen Simmons 06/23/19 07:13PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/23/19 08:03PM
  Re: '78 vespa bravo new carb still wont idleRe: cheetahchrome . cheetahchrome . 06/24/19 03:06PM
  Re: '78 vespa bravo new carb still wont idleRe: Dirty30 Dillon Dirty30 Dillon 06/24/19 03:12PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/24/19 04:24PM
  Re: '78 vespa bravo new carb still wont idleRe: cheetahchrome . cheetahchrome . 06/24/19 04:45PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/24/19 05:14PM
  Re: '78 vespa bravo new carb still wont idleRe: Ike Pipe Ike Pipe 06/25/19 12:29AM
  Re: '78 vespa bravo new carb still wont idleRe: pat splat pat splat 06/25/19 12:35AM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/25/19 07:05AM
  Re: '78 vespa bravo new carb still wont idleRe: cheetahchrome . cheetahchrome . 06/25/19 08:40AM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/25/19 08:56AM
  Re: '78 vespa bravo new carb still wont idleRe: cheetahchrome . cheetahchrome . 06/25/19 09:59AM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/26/19 05:16PM
  Re: '78 vespa bravo new carb still wont idleRe: pat splat pat splat 06/26/19 11:20PM
  Re: '78 vespa bravo new carb still wont idleRe: Brit Wilkens Brit Wilkens 06/27/19 12:31PM
  Re: '78 vespa bravo new carb still wont idleRe: P D P D 06/27/19 01:15PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/27/19 08:24PM
  Re: '78 vespa bravo new carb still wont idleRe: Stephen Simmons Stephen Simmons 06/27/19 08:37PM
  Re: '78 vespa bravo new carb still wont idleRe: cheetahchrome . cheetahchrome . 06/28/19 10:15AM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/28/19 10:20AM
  Re: '78 vespa bravo new carb still wont idleRe: cheetahchrome . cheetahchrome . 06/28/19 10:29AM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/28/19 11:52AM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/28/19 12:03PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/28/19 06:18PM
  Re: '78 vespa bravo new carb still wont idleRe: Stephen Simmons Stephen Simmons 06/28/19 07:24PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/30/19 11:25PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 07/06/19 11:18PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 07/13/19 09:46AM
  Re: '78 vespa bravo new carb still wont idleRe: P D P D 07/13/19 10:04AM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 07/13/19 10:43AM
  Re: '78 vespa bravo new carb still wont idleRe: maxim vdb maxim vdb 07/13/19 04:58PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 07/15/19 05:04PM
  Re: '78 vespa bravo new carb still wont idleRe: P D P D 07/15/19 06:35PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 07/15/19 07:00PM
  Re: '78 vespa bravo new carb still wont idleRe: P D P D 07/15/19 07:13PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 07/15/19 07:27PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 08/04/19 04:11PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 08/04/19 04:19PM
  Re: '78 vespa bravo new carb still wont idleRe: pat splat pat splat 08/04/19 08:40PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 08/12/19 08:54PM
  Re: '78 vespa bravo new carb still wont idleRe: Seth B Seth B 08/12/19 09:39PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 08/14/19 10:11PM
  Re: '78 vespa bravo new carb still wont idleRe: Marc Friedman Marc Friedman 08/13/19 12:48PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 08/14/19 10:10PM
