Re: '78 vespa bravo new carb still wont idle
Stephen Simmons /
> Colin Onda Wrote:
> Thanks guys. I put the 46 jet in, wouldn’t start. I’m assuming too much
> gas. I’m going to grab a gauge tomorrow and check the compression but I
> think I’m going to break down the motor anyways. Replace the crank seal,
> replace the condenser and coils, set the points, clean er up. Do you
> guys this I should split the case and do the crankshaft bearings while i
> have it apart? Also any other things I should look for while I’m in
> there?
Did you pull the head and clean the decompression valve? If the crank spins smoothly I wouldn't worry about crank bearings. But if you really feel as though you want to change them you need heat to get the cases apart and back together. I don't know why but I'm betting your decompression valve is leaking and causing your problems.
  '78 vespa bravo new carb still wont idleTopic by: Colin Onda Colin Onda 06/23/19 10:54AM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/23/19 03:04PM
  Re: '78 vespa bravo new carb still wont idleRe: Stephen Simmons Stephen Simmons 06/23/19 03:46PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/23/19 04:57PM
  Re: '78 vespa bravo new carb still wont idleRe: Stephen Simmons Stephen Simmons 06/23/19 05:09PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/23/19 05:25PM
  Re: '78 vespa bravo new carb still wont idleRe: pat splat pat splat 06/23/19 05:42PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/23/19 06:28PM
  Re: '78 vespa bravo new carb still wont idleRe: Stephen Simmons Stephen Simmons 06/23/19 07:13PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/23/19 08:03PM
  Re: '78 vespa bravo new carb still wont idleRe: cheetahchrome . cheetahchrome . 06/24/19 03:06PM
  Re: '78 vespa bravo new carb still wont idleRe: Dirty30 Dillon Dirty30 Dillon 06/24/19 03:12PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/24/19 04:24PM
  Re: '78 vespa bravo new carb still wont idleRe: cheetahchrome . cheetahchrome . 06/24/19 04:45PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/24/19 05:14PM
  Re: '78 vespa bravo new carb still wont idleRe: Ike Pipe Ike Pipe 06/25/19 12:29AM
  Re: '78 vespa bravo new carb still wont idleRe: pat splat pat splat 06/25/19 12:35AM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/25/19 07:05AM
  Re: '78 vespa bravo new carb still wont idleRe: cheetahchrome . cheetahchrome . 06/25/19 08:40AM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/25/19 08:56AM
  Re: '78 vespa bravo new carb still wont idleRe: cheetahchrome . cheetahchrome . 06/25/19 09:59AM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/26/19 05:16PM
  Re: '78 vespa bravo new carb still wont idleRe: pat splat pat splat 06/26/19 11:20PM
  Re: '78 vespa bravo new carb still wont idleRe: Brit Wilkens Brit Wilkens 06/27/19 12:31PM
  Re: '78 vespa bravo new carb still wont idleRe: P D P D 06/27/19 01:15PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/27/19 08:24PM
  Re: '78 vespa bravo new carb still wont idleRe: Stephen Simmons Stephen Simmons 06/27/19 08:37PM
  Re: '78 vespa bravo new carb still wont idleRe: cheetahchrome . cheetahchrome . 06/28/19 10:15AM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/28/19 10:20AM
  Re: '78 vespa bravo new carb still wont idleRe: cheetahchrome . cheetahchrome . 06/28/19 10:29AM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/28/19 11:52AM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/28/19 12:03PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/28/19 06:18PM
  Re: '78 vespa bravo new carb still wont idleRe: Stephen Simmons Stephen Simmons 06/28/19 07:24PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 06/30/19 11:25PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 07/06/19 11:18PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 07/13/19 09:46AM
  Re: '78 vespa bravo new carb still wont idleRe: P D P D 07/13/19 10:04AM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 07/13/19 10:43AM
  Re: '78 vespa bravo new carb still wont idleRe: maxim vdb maxim vdb 07/13/19 04:58PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 07/15/19 05:04PM
  Re: '78 vespa bravo new carb still wont idleRe: P D P D 07/15/19 06:35PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 07/15/19 07:00PM
  Re: '78 vespa bravo new carb still wont idleRe: P D P D 07/15/19 07:13PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 07/15/19 07:27PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 08/04/19 04:11PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 08/04/19 04:19PM
  Re: '78 vespa bravo new carb still wont idleRe: pat splat pat splat 08/04/19 08:40PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 08/12/19 08:54PM
  Re: '78 vespa bravo new carb still wont idleRe: Seth B Seth B 08/12/19 09:39PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 08/14/19 10:11PM
  Re: '78 vespa bravo new carb still wont idleRe: Marc Friedman Marc Friedman 08/13/19 12:48PM
  Re: '78 vespa bravo new carb still wont idleRe: Colin Onda Colin Onda 08/14/19 10:10PM
