1977 Newport - all stock, but needs new carb. Any suggestions?
Came with an ultra shitty carb so I decided I’m just gonna get a new one. Was thinking of getting a 15mm bing as I can’t find a authentic 12mm. Any thoughts?
Re: 1977 Newport - all stock, but needs new carb. Any suggestions?
Cleats Onionpockets /
Keep an eye out for a 14mm stock carb, but you can't go wrong with a 15mm on the stock setup. It'll allow a little room for mild tuning later on if you so choose.
clean what u have.
Overpriced Parts /
I like a (original to 2 hp aluminum cylinder) 14mm bing better then a 15mm that didn’t come on a stock maxi
Post for a good used one on MA buy+sell page, you will need a 14mm intake unless your bike was a 2 hp model already, you could post for clean good running 12 mm carburetor also if yours won’t clean up,
Now if your bike is a 1hp well you may be thinking and you might want to change the cylinder also because it has a like a 8mm restrictor in the intake
