Re: puch maxi runs great until it get hot, then runs weakly at WOT until death
steven kline /
the coil is external.
i will check on the float level tonight. that could be it, since i did clean the carb 4 or 5 times
I haven't altered the jetting since it came from Detroit moped works. (thats who built this bike originally, so i doubt the jetting is off)
i will find a bosch replacemnet. i dont think the one i replaced was a legit bosh condencer. i also relocated the condencer on the frame. (used a bolt that screws into the original air filter holes) is this good enough placement? or do i have to mount it to the case of the motor itself?
