Re: Batavus HS50 Teardown?
Jesse Z /
@Suzahl I'm finding a lot of puch parts fit these batavus's. The e50 3 wire stator from treats is a direct bolt on if you use the original m48 flywheel. Ive got another bat that I did that to. I'm assuming a magnum fork would probably(?) work on an HS50. But dont have any measurements to back that up.
