Re: 1964 Vespa 90
Seth B /
Pretty much anything will work, if ya let it soak a while. I've used Coca-Cola classic; works great. I've heard of others using straight water. But whatever you use, it's gonna take time to break that chemical bond you gave going on there. Remember, the crank bearings are probably froze up as well, so you may be fighting that resistance. Suspend the engine by the cylinder on some wood blocks, if you can. Then try smacking the piston down & out with a wooden dowel. Use gravity to your advantage.
  1964 Vespa 90Topic by: Owen Sims Owen Sims 07/29/19 05:37PM
  Re: 1964 Vespa 90Re: Nick MBC Nick MBC 07/29/19 05:40PM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 07/29/19 05:50PM
  Re: 1964 Vespa 90Re: Jeff Parr Jeff Parr 07/29/19 05:53PM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 07/29/19 06:01PM
  Re: 1964 Vespa 90Re: Jeff Parr Jeff Parr 07/29/19 06:18PM
  Re: 1964 Vespa 90Re: live ɘvil live ɘvil 07/29/19 06:31PM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 07/29/19 07:02PM
  Re: 1964 Vespa 90Re: Harry Crank Harry Crank 07/29/19 08:35PM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 07/29/19 09:03PM
  Re: 1964 Vespa 90Re: kevy Piepkorn kevy Piepkorn 07/29/19 10:17PM
  Re: 1964 Vespa 90Re: Jeff Parr Jeff Parr 07/30/19 12:23AM
  Re: 1964 Vespa 90Re: Aaron Blair Aaron Blair 07/30/19 06:32AM
  Re: 1964 Vespa 90Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 07/30/19 08:42AM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 07/30/19 09:14AM
  Re: 1964 Vespa 90Re: tom wizard tom wizard 07/30/19 05:17PM
  Re: 1964 Vespa 90Re: Dirty30 Dillon Dirty30 Dillon 08/02/19 10:53AM
  Re: 1964 Vespa 90Re: kevy Piepkorn kevy Piepkorn 07/30/19 08:02PM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 07/31/19 10:04PM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 07/31/19 10:05PM
  Re: 1964 Vespa 90Re: Jeff Parr Jeff Parr 07/31/19 10:52PM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 08/01/19 10:15PM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 08/01/19 11:01PM
  Re: 1964 Vespa 90Re: Jeff Parr Jeff Parr 08/01/19 11:17PM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 08/01/19 11:45PM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 08/02/19 09:50AM
  Re: 1964 Vespa 90Re: Jeff Parr Jeff Parr 08/02/19 10:17AM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 08/02/19 10:18AM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 08/02/19 11:28AM
  Re: 1964 Vespa 90Re: Jeff Parr Jeff Parr 08/02/19 11:33AM
  Re: 1964 Vespa 90Re: Seth B Seth B 08/02/19 11:38AM
  Re: 1964 Vespa 90Re: Jeff Parr Jeff Parr 08/02/19 01:29PM
  Re: 1964 Vespa 90Re: Seth B Seth B 08/02/19 03:19PM
  Re: 1964 Vespa 90Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 08/02/19 06:51PM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 08/02/19 09:42PM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 09/29/19 10:45AM
  Re: 1964 Vespa 90Re: Jeff Parr Jeff Parr 09/29/19 11:15AM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 09/29/19 11:40AM
  Re: 1964 Vespa 90Re: Jeff Parr Jeff Parr 09/29/19 12:24PM
