Re: 1964 Vespa 90
Remove the nuts at the base of the cylinder. Crack the bond between the cylinder and engine case to see if the crank still moves. If it does, turn the crank to push the piston(and cylinder) as far away from the engine case as possible. Wedge some wood blocks between the base of the cylinder and engine case, then beat the piston down and out of the cylinder. Once the piston starts to move, you make need to add more wood blocks between the cylinder base and engine case if needed.
  1964 Vespa 90Topic by: Owen Sims Owen Sims 07/29/19 05:37PM
  Re: 1964 Vespa 90Re: Nick Haber Nick Haber 07/29/19 05:40PM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 07/29/19 05:50PM
  Re: 1964 Vespa 90Re: Jeff Parr Jeff Parr 07/29/19 05:53PM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 07/29/19 06:01PM
  Re: 1964 Vespa 90Re: Jeff Parr Jeff Parr 07/29/19 06:18PM
  Re: 1964 Vespa 90Re: live ɘvil live ɘvil 07/29/19 06:31PM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 07/29/19 07:02PM
  Re: 1964 Vespa 90Re: Harry Crank Harry Crank 07/29/19 08:35PM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 07/29/19 09:03PM
  Re: 1964 Vespa 90Re: . chillywillie . chillywillie 07/29/19 10:17PM
  Re: 1964 Vespa 90Re: Jeff Parr Jeff Parr 07/30/19 12:23AM
  Re: 1964 Vespa 90Re: Aaron Blair Aaron Blair 07/30/19 06:32AM
  Re: 1964 Vespa 90Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 07/30/19 08:42AM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 07/30/19 09:14AM
  Re: 1964 Vespa 90Re: tom wizard tom wizard 07/30/19 05:17PM
  Re: 1964 Vespa 90Re: Dirty30 Dillon Dirty30 Dillon 08/02/19 10:53AM
  Re: 1964 Vespa 90Re: . chillywillie . chillywillie 07/30/19 08:02PM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 07/31/19 10:04PM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 07/31/19 10:05PM
  Re: 1964 Vespa 90Re: Jeff Parr Jeff Parr 07/31/19 10:52PM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 08/01/19 10:15PM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 08/01/19 11:01PM
  Re: 1964 Vespa 90Re: Jeff Parr Jeff Parr 08/01/19 11:17PM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 08/01/19 11:45PM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 08/02/19 09:50AM
  Re: 1964 Vespa 90Re: Jeff Parr Jeff Parr 08/02/19 10:17AM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 08/02/19 10:18AM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 08/02/19 11:28AM
  Re: 1964 Vespa 90Re: Jeff Parr Jeff Parr 08/02/19 11:33AM
  Re: 1964 Vespa 90Re: Seth B Seth B 08/02/19 11:38AM
  Re: 1964 Vespa 90Re: Jeff Parr Jeff Parr 08/02/19 01:29PM
  Re: 1964 Vespa 90Re: Seth B Seth B 08/02/19 03:19PM
  Re: 1964 Vespa 90Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 08/02/19 06:51PM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 08/02/19 09:42PM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 09/29/19 10:45AM
  Re: 1964 Vespa 90Re: Jeff Parr Jeff Parr 09/29/19 11:15AM
  Re: 1964 Vespa 90Re: Owen Sims Owen Sims 09/29/19 11:40AM
  Re: 1964 Vespa 90Re: Jeff Parr Jeff Parr 09/29/19 12:24PM
