Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fire
. chillywillie /
I get tired of pedaling so i use a drill to turn it over. Can you borrow a timing gun to check the timing when you turn it over? if the plug is wet you might be flooding it and fouling the plug. look up freds guide I believe on the wiki and go through those steps. 2 strokes have to be real close to right on to run. I wouldn't thing you would have to shut the fuel off and pedal until it runs. I would shut the fuel off,spray a little mixed gas in the carb put the choke on and pedal or turn it over to see if it will start and then go from there.
  My jawa 210 has spark, compression, and fuel in the cylinder but wont fireTopic by: Blukas Lukas Blukas Lukas 07/29/19 09:26PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: . chillywillie . chillywillie 07/29/19 10:11PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/29/19 10:44PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: * * * * 07/30/19 01:30AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/29/19 10:42PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Frank Bailey Frank Bailey 07/30/19 06:25AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/30/19 10:30AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/30/19 11:11AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Frank Bailey Frank Bailey 07/30/19 08:37PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: P D P D 07/30/19 09:48PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/30/19 11:23AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/30/19 01:30PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: * * * * 07/30/19 01:41PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/30/19 02:36PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/30/19 02:40PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/30/19 03:41PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/30/19 04:12PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: . chillywillie . chillywillie 07/30/19 07:53PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 08/02/19 05:36PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 08/02/19 05:40PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Brian Terrell Brian Terrell 08/06/19 11:51AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: paul goodman paul goodman 08/07/19 03:36AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 08/07/19 09:36PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 08/08/19 12:09PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 08/14/19 12:36PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: . chillywillie . chillywillie 08/15/19 08:23PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: B the Moped B the Moped 08/16/19 04:16AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: paul goodman paul goodman 08/19/19 04:01AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: paul goodman paul goodman 08/20/19 03:45AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 08/22/19 05:30PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 08/23/19 03:36PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 08/28/19 08:04PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: paul goodman paul goodman 09/24/19 08:22AM
