Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fire
Blukas Lukas /
And now it works good! The exhaust temps are alittle sizzling but i was revving it up in one spot and i didnt test drive it, but i will still have to replace that thyristor cause when its under load (when a lamp is on or the horn is beeping) it bogs down, but for now its good, thanks!, also heres a good forum to adjust the timing
https://www.mopedarmy.com/wiki/Ignition_timing_for_CDI
  My jawa 210 has spark, compression, and fuel in the cylinder but wont fireTopic by: Blukas Lukas Blukas Lukas 07/29/19 09:26PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: . chillywillie . chillywillie 07/29/19 10:11PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/29/19 10:44PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: * * * * 07/30/19 01:30AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/29/19 10:42PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Frank Bailey Frank Bailey 07/30/19 06:25AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/30/19 10:30AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/30/19 11:11AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Frank Bailey Frank Bailey 07/30/19 08:37PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: P D P D 07/30/19 09:48PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/30/19 11:23AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/30/19 01:30PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: * * * * 07/30/19 01:41PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/30/19 02:36PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/30/19 02:40PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/30/19 03:41PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/30/19 04:12PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: . chillywillie . chillywillie 07/30/19 07:53PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 08/02/19 05:36PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 08/02/19 05:40PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Brian Terrell Brian Terrell 08/06/19 11:51AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: paul goodman paul goodman 08/07/19 03:36AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 08/07/19 09:36PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 08/08/19 12:09PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 08/14/19 12:36PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: . chillywillie . chillywillie 08/15/19 08:23PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: B the Moped B the Moped 08/16/19 04:16AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: paul goodman paul goodman 08/19/19 04:01AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: paul goodman paul goodman 08/20/19 03:45AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 08/22/19 05:30PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 08/23/19 03:36PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 08/28/19 08:04PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: paul goodman paul goodman 09/24/19 08:22AM
