Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fire
paul goodman /
hi, i have a similar starting problem. look up under general discussion, ie jawa 210 49cc 2 sroke. mine just died on me, when it got difficult to start, after leaving it for an hour. i also give it a a tear drop of easy start, starts instantly. i fitted an nt 49cc carb. drilled a small hole about 1/4 inch, just to the right of the filter, found a rubber plug. to push in the hole. quick and easy, for emergency. i carry a small plastic eye bottle with me, to fill it, spray some easy start into a cap of some sort, then get the eye bottle squeeze it and suck up the easy start. you do not need much in the bottle. a tear drop usually works. i call it a mechanic in a bottle. assuming your engine and electrics a normally very good. Unfortunately it no longer starts mine.
i think i have a stator problem, no spark, i fitted the new type thyristor with the built in coil. 3 spade tags. red wire on the G then yellow, on the I and a white one on the other I POSITION, hope this is correct. but no sign of a spark. i use a ngk b6hs plug. never given a problem. fitted a new HT lead, and cap. waiting for some test equipment to test further. removed the cut out switch, still no start, going to fit a new on off switch, better than the orginal. Any ideas how to test the stator??
  My jawa 210 has spark, compression, and fuel in the cylinder but wont fireTopic by: Blukas Lukas Blukas Lukas 07/29/19 09:26PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: . chillywillie . chillywillie 07/29/19 10:11PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/29/19 10:44PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: * * * * 07/30/19 01:30AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/29/19 10:42PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Frank Bailey Frank Bailey 07/30/19 06:25AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/30/19 10:30AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/30/19 11:11AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Frank Bailey Frank Bailey 07/30/19 08:37PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: P D P D 07/30/19 09:48PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/30/19 11:23AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/30/19 01:30PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: * * * * 07/30/19 01:41PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/30/19 02:36PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/30/19 02:40PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/30/19 03:41PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 07/30/19 04:12PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: . chillywillie . chillywillie 07/30/19 07:53PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 08/02/19 05:36PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 08/02/19 05:40PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Brian Terrell Brian Terrell 08/06/19 11:51AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: paul goodman paul goodman 08/07/19 03:36AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 08/07/19 09:36PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 08/08/19 12:09PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 08/14/19 12:36PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: . chillywillie . chillywillie 08/15/19 08:23PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: B the Moped B the Moped 08/16/19 04:16AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: paul goodman paul goodman 08/19/19 04:01AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: paul goodman paul goodman 08/20/19 03:45AM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 08/22/19 05:30PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 08/23/19 03:36PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: Blukas Lukas Blukas Lukas 08/28/19 08:04PM
  Re: My jawa 210 has spark, compression, and fuel in the cylinder but wont fireRe: paul goodman paul goodman 09/24/19 08:22AM
