hi,all. finely got the bike to fire, after 2 weeks, used an electric drill to spin the stator. to check the plug for a spark, good spark, i thought great, re checked the wires, soldered some wires, to cut out switch, using the new thyristor with the built in coil.
but it won,t stay running, stopped and started 2 or three times, revs fine. then died. took the plug out, rested against the head, used the drill to spin the stator, now no spark again, thinking something is breaking down when it gets warm, left overnight. now just going to see if it will start from cold this morning, not hopefull. running out of ideas. may have to change all parts for new, stator, wiring, ect to find a cure, it,s a real pig. carb, plug, thyristor, ect all good. it,s electrical somewhere, waggled the wires about, still get continuity on the mutlti meter on tested wires, from the stator. will keep trying. bye for now. paul.
