Tomos Clutch Bell Brass Bushing Question
Simon Belmont /
I have A55 Tomos clutch bell and when taking it out, I noticed that brass bushing that's inside can easily be moved in & out, is that normal?
The reason I ask is I have another clutch bell from A35 engine and the brass bushing inside it is not movable at all.
Re: Tomos Clutch Bell Brass Bushing Question
No that bushing is pressed into the bell.
I have exactly the same thing happening with mine. No idea why it's happened. Going to press another in there and see what happens.
Use a .5 to .7mm thicker of a bushing helps to , but it you get up around .7mm thicker recommend useing a press
♣Slew Foot♣ /
Hey that? Springy thing on the main shaft there? that might be the internal Kickstart cage and needle bearings taking a chew that bushing is the first thing that will start sliding around just so you know
