Re: Ciao ignition problem
Bill Shaw /
New points , lubed cam, proper sized main jet, timing correct, air filter clean, copper core plug wire w/ good connections on both ends, brake light works properly.
Should the voltage into the coil be more than 1/2 volt? (edited)
