Re: G3 505/D SLOW
Potr zebie /
get the socket cap i mentioned and blow out the metal shavings
if there are still any threads inside the hole, SLOWLY and GENTLY screw in the bolt you bought (put a couple drops of oil to make sure you dont force anything) and make sure its fully in but dont torque it
just give it a slight tug and see if theres any movement to the bolt
if not, take out the bolt, clean up all the the oil and jb weld it back in
if the bolt moves you may have to rethread it and get a bigger bolt or just close the hole completely with jb weld
