Re: G3 505/D SLOW
Born to be WillD /
> Rebel Moby Wrote:
> take a look on the right side of the motor on the cylinder side fin,
> should be number on the casting 30km 40km or 50km. If it is 30km then
> 20mph is all you going to get stock, 40km and you will be hitting 25mph
> and 50km is a 30mph rated cylinder... porting will fix that issue, but
> them you will have to fool around with the carb.
that square jug is the 50 every time.
Everything above is pretty much what I would've said too, from the 1st post my immediate thoughts were definitely leaky decomp and very likely clogged exhaust.
seems like you're addressing those. my approach would be to clean the hell outta that port with brake cleaner and try to thread in a plug (not the valve - see the 505/1a performance wiki page - section on plugging decomp) maybe using some epoxy sealer to help.
after that other issues maybe leaky crank seals, Other sachsy type issues are they slip timing pretty regularly and generic attention to points etc is key as ever.
Want to reply to this thread?
