Re: v1 low compression- won't start
Aaron Blair /
Dude I've never worked on a v1, but I think your timed like 180 degrees out now from flipping the stator.unless you can move the points cam on a v1, in which case I'm a dummy. The points should start closing near tdc, why did you flip it? (edited)
