Just joined the Moped Army - tons a first timer questions
Jordan Carter /
Hi All,
I just purchased a 1979 Puch Magnum II and wanted to create a thread to ask many questions I have as a new owner. I've read several of the wikis and also watched many youtube videos, but I've still got a bunch of new questions as a new rider/owner. I would appreciate any and all feedback on the below:
1) Rich/Lean: I'm having a really hard time figuring this out. I've attached a picture or the plug if that helps.
2) Oil on Spark Plug: I'm noticing oil around the spark plug. Is this normal?
3) Adjusting the throttle: I've noticed that sometimes pulling all the way on the throttle is actually less gas than twisting it ~85% of the way, is there a method to adjust this?
4) Springs for Brakes / throttle: the brake can be a bit sticky where the brake levers stick a bit after I've released them (same thing for the throttle). How can I increase the tension on these?
5) Choke: I have ta 1/14/164 bing Carb, and am unsure how to use the choke. The engine doesn't seem to idle well with the choke pushed all the way down. Where should this choke slide be positioned for typical riding and how is it used? (note: I edited this post to add this last question)
Thank you (edited)
  Just joined the Moped Army - tons a first timer questionsTopic by: Jordan Carter Jordan Carter 08/03/19 03:39PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Don Ohio Don Ohio 08/03/19 04:42PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Rebel Moby Rebel Moby 08/03/19 05:14PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Jordan Carter Jordan Carter 08/03/19 08:02PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Seth B Seth B 08/04/19 01:21AM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Rebel Moby Rebel Moby 08/04/19 09:22AM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Daniel '' Daniel '' 08/04/19 01:05PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Overpriced Parts Overpriced Parts 08/03/19 08:41PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Jordan Carter Jordan Carter 08/03/19 10:14PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/04/19 12:49AM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 08/04/19 08:39AM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Marc Friedman Marc Friedman 08/04/19 02:54PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Daniel '' Daniel '' 08/04/19 04:17PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Marc Friedman Marc Friedman 08/04/19 04:25PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Jordan Carter Jordan Carter 08/04/19 03:52PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Jordan Carter Jordan Carter 08/04/19 07:13PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Overpriced Parts Overpriced Parts 08/04/19 08:56PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 08/07/19 08:49AM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Jordan Carter Jordan Carter 08/04/19 09:08PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Rebel Moby Rebel Moby 08/05/19 09:38AM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Jeff Parr Jeff Parr 08/06/19 02:51PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Jordan Carter Jordan Carter 08/07/19 08:21AM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Mike Boyd Mike Boyd 08/07/19 12:37PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Jordan Carter Jordan Carter 08/07/19 06:26PM
