Re: Just joined the Moped Army - tons a first timer questions
Jordan Carter /
Got it. I believe I understand the choke now - thank you.
Also agree that it’s a MK II - sorry I did not mean to cause confusion.
I’ll intend to upset around a 70 jet.
For the weeping (oil around the spark plug), should I be concerned there? Is there a need or way to fix that?
Also for the intake, how can I check if it’s 14mm? Can I just measure the opening there? Is there a method that doesn’t require dismounting the carb?
  Just joined the Moped Army - tons a first timer questionsTopic by: Jordan Carter Jordan Carter 08/03/19 03:39PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Don Ohio Don Ohio 08/03/19 04:42PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Rebel Moby Rebel Moby 08/03/19 05:14PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Jordan Carter Jordan Carter 08/03/19 08:02PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Seth B Seth B 08/04/19 01:21AM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Rebel Moby Rebel Moby 08/04/19 09:22AM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Daniel '' Daniel '' 08/04/19 01:05PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Overpriced Parts Overpriced Parts 08/03/19 08:41PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Jordan Carter Jordan Carter 08/03/19 10:14PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: ♣Slew Foot♣ ♣Slew Foot♣ 08/04/19 12:49AM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 08/04/19 08:39AM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Marc Friedman Marc Friedman 08/04/19 02:54PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Daniel '' Daniel '' 08/04/19 04:17PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Marc Friedman Marc Friedman 08/04/19 04:25PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Jordan Carter Jordan Carter 08/04/19 03:52PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Jordan Carter Jordan Carter 08/04/19 07:13PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Overpriced Parts Overpriced Parts 08/04/19 08:56PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 08/07/19 08:49AM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Jordan Carter Jordan Carter 08/04/19 09:08PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Rebel Moby Rebel Moby 08/05/19 09:38AM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Jeff Parr Jeff Parr 08/06/19 02:51PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Jordan Carter Jordan Carter 08/07/19 08:21AM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Mike Boyd Mike Boyd 08/07/19 12:37PM
  Re: Just joined the Moped Army - tons a first timer questionsRe: Jordan Carter Jordan Carter 08/07/19 06:26PM
