Lots of goodly help for you so I will just get on the #3
Remove the carb or have someone help if you don't want to disturb it. Twist the throttle to 1/2 travel and look inside the carb bore, the bottom of the slide should be 1/2 up... etc...
ALSO
There are no silly questions, you are learning, everyone needs to learn things somehow, soon enough you are going to be the guy kicking in suggestions for new folks.
> Jordan Carter Wrote:
> Thanks already for the help here a few follow up questions on these same
> points.
> 3) I understand what you’re saying about the position of the slide, but
> how can I tell how the slide is positioned within the carb?
> Sorry for all the silly questions. I’ve enjoyed learning this far here -
> it will take me sometime to get up to speed.
