I’m a 100% moped guy but my friend bought a scooter and it ran pretty good ( hard to start when sits along time) didn’t idle well but did run and move. Was told the valves needed to be adjusted so I did that for him but now it cranks but won’t start !!!!! Would adjusting the valves cause this ??? Also new battery, carb and it still is getting spark. Help !!!!!!
50cc four stroke scooter
Re: 50cc four stroke scooter
Did you adjust the valves correctly? Did you touch the timing at all? If it ran before you touched the valves but doesn't now I'd say you need to check the valves again
Did you have the timing marks right and have you done a compression test? What brand is it?
This Repair forum is not the OFF-TOPIC forum where this belongs. If as you say,yer a moped guy, you should post in the appropriate forum.
Fly scooter. It’s been running ok just hard to start and didn’t like to idle. Was hearing valve lash noise
Sorry just was in a rush since my buddy needed it back right away. I have over 8 mopeds ( old school)
Did you adjust the valves with them being stone cold? You cannot adjust warm valves.
Yes been sitting for two days. I’m going to take all the plastic back of and the side cover to make sure it’s top center.
The diaphragm PETCOCK is not opening or leaking air and could be the vacuum line not getting enough suction to oped fuel petcock this happens on 99% of these scooters until you get hat straitened out you will kill batteries and starter motors...
Went out check it and yes I was one revaluation off. Still have good spark but still won’t start ? I have a new fuel pump on the tank but instead of pulsating fuel it’s just pouring out. Rapped it a few times still doing it. Disconnect the fuel line took the plug out and sprayed starting fluid right into the top end and out the plug in and still doesn’t fire. I’m lost. I work on mopeds all the times and never have issues
Well thought I figured it out but still not starting. Seems to be good spark but did notice the fuel isn’t pulsating it’s just pouring in. Disconnect it took out the plug and sprayed starting fluid right into the head and it still doesn’t fire. Wtf like I said I hate dam scooters.
Does the petcock have a Prime position ? That would allow steady flow .
No petcock on this scooter. 2007 flyscooter 50cc four stroke. It ran ok ( just hard to start ) before adjusting the dam valves no my buddy is freakin out. Fuel pumps of the engine but did notice the fuel was constantly flowing now which it shouldn’t but disconnect it and sprayed starting fluid and still nothing. What the hell could of went wrong
So , the fuel valve is stuck open . Blow into the vacuum line that comes from the valve .
It might just be stuck or the oring or the diaphragm may be bad .
What's the compression reading ?
Going to grab my buddies now to check. Just crazy because I drove it in and it’s been being used for the last month. Someone said maybe the valves are not seating now that I adjusted it ??
True , IF you adjusted them too tight .
Well the first time I did them I wasn’t at top dead center I was off one turn but did it right this time and did them .004. Compression should be around 120 I believe ? I’ll message you after I get that done. Just all crazy all this by adjusting two dam valves
Not getting any compression at all !!!! Piston is moving. Wtf is going on.
It has no compression at all now since I adjust the valves. Ran before and now nothing. I’ll check the valves again. Was told to shoot air down the spark plug hole and see where the air is coming from. I hate scooters
Are you placing the flywheel at the fire mark with the cam lobes pointing away from the valves ?
Adjust the valves at .008 instead of .004. sometimes the cam will somehow get a high spot on a lobe and it will act as a decompression valve.
Fly wheel is at T and the two small holes and the bigger center is lined up like they say they should be. Also put 50 psi in the plug hole and don’t hear any leak. Rechecked the valves and both at .004 and the .005 doesn’t fit in.
Then back to .004 or leave it
Done this 3 times and still no compression???? Drove it in ??? Put air into spark plug hole and didn’t hear any leaks, have spark, ect. All I did was removed valve cover an adjusted them to .004 a .005 will not fit, 3 holes in the gear are lined up ect..... just puzzled that it ran pretty good ( hard to start ) scooter has 1200 miles when I drove it in and waited a day and did the work an now 0 psi has spark and even tried starting fluid in the spark plug hole
Try pulling the tranny oil fill plug and inserting air in the plug hole . If you hear hissing or such from the oil fill hole it's time for new rings , at least , no matter the mileage , as you have no idea what that motor went through prior .
On the same note , did you have the exhaust header and the intake disconnected when you blew air in the plug hole before ? If you didn't , you'd likely not hear anything .
And , of course , these tests should be done with the piston at TDC compression stroke . (edited)
Was at top dead center and no didn’t take the intake off or the exhaust. Just weird that I drove the thing to my house and now all this. Was just hard to start and didn’t like to idle so I bought a new carburetor. Did hear some tapping too and I was told to do the valves which were very tight.
> very tight.
All that^ sounds like low compression and the tapping might just have been the last straw . Take a real compression test or better , do a leak test like I described above .
I'm thinking it's time for some top end work . More than just an adjustment that may have been way too late . There could easily be a brunt valve .
