Re: 50cc four stroke scooter
live ɘvil /
Ok, after reading from beginning to end it sounds like you adjusted the valves when the motor was on exhaust stroke instead of compression stroke.
Forget everything you know about 2 strokes for a minute.
On a four stroke the cam turns half as fast as the crank. So it takes two full revolutions of the crank to complete all four strokes. What this means is that the piston comes to "tdc" (next to the "f" mark) twice in one combustion cycle.
If you did not have it on the compression stroke when you adjusted your valves then they are way too loose because they were partially open during exhaust stroke when you set the gaps.
To tell where you need to be remove plug and place finger over hole while rotating engine. When the piston comes to "tdc" on the compression stroke you will feel it push your finger off. Thats where the engine needs to be to adjust the valves with it lined up at "tdc"
Remember, that an engine fires a few degrees before "tdc". So any "tdc" marks will come after the "f".
Also be damn sure you're rotating the engine in the correct direction. (edited)
  50cc four stroke scooterTopic by: Brian Terrell Brian Terrell 08/05/19 02:21PM
  Re: 50cc four stroke scooterRe: Nick MBC Nick MBC 08/05/19 02:34PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/06/19 10:24AM
  Re: 50cc four stroke scooterRe: Jeff Parr Jeff Parr 08/05/19 03:01PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/05/19 03:33PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/06/19 02:42PM
  Re: 50cc four stroke scooterRe: P D P D 08/06/19 03:54PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/06/19 05:06PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/06/19 07:25PM
  Re: 50cc four stroke scooterRe: P D P D 08/06/19 07:33PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/06/19 08:35PM
  Re: 50cc four stroke scooterRe: P D P D 08/06/19 08:41PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/06/19 09:01PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/06/19 07:23PM
  Re: 50cc four stroke scooterRe: Don Ohio Don Ohio 08/05/19 03:04PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/05/19 03:34PM
  Re: 50cc four stroke scooterRe: Moped Lar (OFMC) Moped Lar (OFMC) 08/05/19 04:30PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/05/19 04:44PM
  Re: 50cc four stroke scooterRe: Bob Selby Bob Selby 08/05/19 09:06PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/05/19 10:03PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/06/19 10:30AM
  Re: 50cc four stroke scooterRe: P D P D 08/06/19 10:40AM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/06/19 10:56AM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/06/19 10:57AM
  Re: 50cc four stroke scooterRe: P D P D 08/06/19 11:31AM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/06/19 11:37AM
  Re: 50cc four stroke scooterRe: P D P D 08/06/19 11:44AM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/06/19 11:49AM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/06/19 02:05PM
  Re: 50cc four stroke scooterRe: Stephen Simmons Stephen Simmons 08/06/19 04:51PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/06/19 05:09PM
  Re: 50cc four stroke scooterRe: Ryan Graeme Ryan Graeme 08/08/19 02:39PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/08/19 04:02PM
  Re: 50cc four stroke scooterRe: live ɘvil live ɘvil 08/06/19 10:27PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/06/19 10:39PM
  Re: 50cc four stroke scooterRe: live ɘvil live ɘvil 08/06/19 10:43PM
  Re: 50cc four stroke scooterRe: live ɘvil live ɘvil 08/06/19 10:48PM
  Re: 50cc four stroke scooterRe: live ɘvil live ɘvil 08/06/19 10:55PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/07/19 12:03AM
  Re: 50cc four stroke scooterRe: live ɘvil live ɘvil 08/07/19 01:00AM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/07/19 01:24AM
  Re: 50cc four stroke scooterRe: live ɘvil live ɘvil 08/07/19 11:57AM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/07/19 12:06PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/07/19 12:03PM
  Re: 50cc four stroke scooterRe: live ɘvil live ɘvil 08/07/19 12:13PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/07/19 12:18PM
  Re: 50cc four stroke scooterRe: live ɘvil live ɘvil 08/07/19 12:36PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/07/19 12:47PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/07/19 12:21PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/07/19 01:23PM
  Re: 50cc four stroke scooterRe: live ɘvil live ɘvil 08/07/19 02:02PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/07/19 02:46PM
  Re: 50cc four stroke scooterRe: live ɘvil live ɘvil 08/07/19 02:46PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/07/19 12:12AM
  Re: 50cc four stroke scooterRe: Overpriced Parts Overpriced Parts 08/07/19 06:22PM
  Re: 50cc four stroke scooterRe: live ɘvil live ɘvil 08/08/19 02:13AM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/08/19 08:57AM
  Re: 50cc four stroke scooterRe: live ɘvil live ɘvil 08/08/19 01:04PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/08/19 01:07PM
  Re: 50cc four stroke scooterRe: live ɘvil live ɘvil 08/08/19 01:12PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/08/19 01:18PM
  Re: 50cc four stroke scooterRe: live ɘvil live ɘvil 08/08/19 02:00PM
  Re: 50cc four stroke scooterRe: live ɘvil live ɘvil 08/08/19 02:16PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/08/19 02:20PM
  Re: 50cc four stroke scooterRe: live ɘvil live ɘvil 08/08/19 02:25PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/08/19 02:37PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/08/19 08:12PM
  Re: 50cc four stroke scooterRe: live ɘvil live ɘvil 08/09/19 02:26AM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/09/19 09:36AM
  Re: 50cc four stroke scooterRe: live ɘvil live ɘvil 08/09/19 01:07PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/09/19 01:40PM
  Re: 50cc four stroke scooterRe: live ɘvil live ɘvil 08/09/19 02:24PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/09/19 02:55PM
  Re: 50cc four stroke scooterRe: live ɘvil live ɘvil 08/09/19 03:09PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/09/19 03:22PM
  Re: 50cc four stroke scooterRe: live ɘvil live ɘvil 08/09/19 03:28PM
  Re: 50cc four stroke scooterRe: Brian Terrell Brian Terrell 08/09/19 03:42PM
  Re: 50cc four stroke scooterRe: live ɘvil live ɘvil 08/09/19 03:46PM
