Re: Motobecane av88 - only runs at high rpm
Rebel Moby /
Throw in a oring at the union between the carb and the intake, 5/8 x 13/16 x 3/32 oring is a great fit into the 14mm carb sizes.
Might have smeared the piston a little when it spooled down with no fuel if it happened when the engine was already fully heat soaked. May need to clean up the piston and throw in new rings.
