Re: 1990 dt50 stuck in first
Nick Haber /
The easiest thing it could possibly be is the shifter is bent, letting you shift down but then it hits when you try to shift up. This literally just happened on a friend's CB400, we were about to tear apart the transmission when we noticed that.
Otherwise you'll have to pull the bottom end again and check to make sure everything is aligned/spaced properly
Want to reply to this thread?
