> Cleats Onionpockets Wrote:
> Welp, turns out I need to tear down the engine anyway. While cranking it
> over, I noticed a wobble at the flywheel, which turned out to be a bent
> crankshaft on the flywheel side. C'est la vie.....
Cranks are typically 3 piece. They can be knocked out of alignment without bending. Could be as simple as re aligning a crank that's been dropped.
