Re: V2 epic failure
Seth B /
Need more info... What's going on? Belts probably slipping, or? Try turning flywheel or variator by hand, not pedal crank. Your engine is tight and new, with good compression. Your belt needs to grip good to turn the motor over when you pedal.
Want to reply to this thread?
