Re: V2 epic failure
Les B. /
Success! Got it running guys! Thanks to all who helped with tips, insight, and kidding. I had a home plumbing job to do first , afterward it wasn't too hot so I set up the garage and went to work. Tore the ignition apart. Sanded as instructed. Used the grinding paste on the crank, took over an hour to shine it up. Took it out back ,used the compressor and blew all that carp out off the flywheel, also the coils ,points ,etc. Got it running about 5pm! Braaaapp! Just need to sort out the throttle cable. It's not seating properly. Probably get a new one. Also no lights, brake lite works. But it's running. I'm going to clean it up and post pics. Also there's a quick video at brownies.les, Instagram. 8)
