Re: Giving up on getting this tire to fit.
Overpriced Parts /
> P D Wrote:
> I've always tried to use the KISS ( Keep I Simple , Stupid ) method .
> Why make the job more complicated than needed ?
> A little dish soap and a couple screwdrivers gets the job done before
> you even find the zip ties . And , you get to use those zip ties for
> what they were intended ... snugging cables / wiring neatly out of the
> way and securing prisoners hands behind their backs . ;)
The secret to getting a tire on easy it is to get both of the beads of the tire in the middle of the rim where it smaller right away and throughout the whole process
Blacks zip are only for temporary use (not for prisoners they have stronger ones them ha ha)
Don't use water (which dish soap contains mostly) on steel rims because they will rust from the inside from the get go.
No tools against the painted rims means no chips and on Chrome plated rims means no scratches in the chrome by the tire which will cause rust,
Even if you cannot see the marks left by tire irons because hid by the tire, corrosion in aluminum rims and rust in the steel rim will form there why would you want that,
I’ve been changing tires since age 8 and I’d have to say the zip ties is the best method for Mopeds/small bikes because it gets the bead of both sides of the tire right into the middle of the rim and keeps it there and it doesn’t pinch tubes,
Most times the tire and tube goes on with just with your hands and if you do need a tire iron at the very end it’s just one pull of the tire iron and that’s it,
Believe me I was a unbeliever too but now that’s the only way I do it
  Giving up on getting this tire to fit.Topic by: Tomas Molinari Tomas Molinari 08/11/19 05:34PM
  Re: Giving up on getting this tire to fit.Re: P D P D 08/11/19 06:06PM
  Re: Giving up on getting this tire to fit.Re: Tomas Molinari Tomas Molinari 08/11/19 06:51PM
  Re: Giving up on getting this tire to fit.Re: Den 23 Den 23 08/11/19 06:34PM
  Re: Giving up on getting this tire to fit.Re: Tomas Molinari Tomas Molinari 08/11/19 06:52PM
  Re: Giving up on getting this tire to fit.Re: Tomas Molinari Tomas Molinari 08/11/19 07:30PM
  Re: Giving up on getting this tire to fit.Re: pat splat pat splat 08/11/19 07:33PM
  Re: Giving up on getting this tire to fit.Re: Tomas Molinari Tomas Molinari 08/11/19 07:42PM
  Re: Giving up on getting this tire to fit.Re: live ɘvil live ɘvil 08/12/19 01:23AM
  Re: Giving up on getting this tire to fit.Re: alex . alex . 08/12/19 12:57AM
  Re: Giving up on getting this tire to fit.Re: Den 23 Den 23 08/12/19 06:47AM
  Re: Giving up on getting this tire to fit.Re: live ɘvil live ɘvil 08/12/19 11:43AM
  Re: Giving up on getting this tire to fit.Re: Dirty30 Dillon Dirty30 Dillon 08/12/19 09:53AM
  Re: Giving up on getting this tire to fit.Re: live ɘvil live ɘvil 08/12/19 12:11PM
  Re: Giving up on getting this tire to fit.Re: Monti S Monti S 08/12/19 11:17AM
  Re: Giving up on getting this tire to fit.Re: Trent Anderson Trent Anderson 08/13/19 07:12PM
  Re: Giving up on getting this tire to fit.Re: alex . alex . 08/13/19 07:33PM
  Re: Giving up on getting this tire to fit.Re: Overpriced Parts Overpriced Parts 08/13/19 10:41PM
  Re: Giving up on getting this tire to fit.Re: P D P D 08/14/19 08:21AM
  Re: Giving up on getting this tire to fit.Re: Overpriced Parts Overpriced Parts 08/14/19 12:52PM
  Re: Giving up on getting this tire to fit.Re: Trent Anderson Trent Anderson 08/14/19 01:29PM
  Re: Giving up on getting this tire to fit.Re: Tyler Hautau Tyler Hautau 08/14/19 03:44PM
  Re: Giving up on getting this tire to fit.Re: P D P D 08/14/19 04:12PM
  Re: Giving up on getting this tire to fit.Re: alex . alex . 08/15/19 12:27AM
  Re: Giving up on getting this tire to fit.Re: live ɘvil live ɘvil 08/15/19 03:23AM
  Re: Giving up on getting this tire to fit.Re: P D P D 08/15/19 08:11AM
  Re: Giving up on getting this tire to fit.Re: alex . alex . 08/15/19 01:53PM
  Re: Giving up on getting this tire to fit.Re: P D P D 08/15/19 06:06PM
  Re: Giving up on getting this tire to fit.Re: live ɘvil live ɘvil 08/16/19 12:27AM
  Re: Giving up on getting this tire to fit.Re: P D P D 08/16/19 07:59AM
  Re: Giving up on getting this tire to fit.Re: live ɘvil live ɘvil 08/16/19 06:51PM
  Re: Giving up on getting this tire to fit.Re: P D P D 08/16/19 07:15PM
  Re: Giving up on getting this tire to fit.Re: mark alan mark alan 08/14/19 11:49PM
  Re: Giving up on getting this tire to fit.Re: Richard Eberline Richard Eberline 08/15/19 02:17PM
  Re: Giving up on getting this tire to fit.Re: alex . alex . 08/15/19 06:56PM
  Re: Giving up on getting this tire to fit.Re: Seth B Seth B 08/16/19 08:06PM
  Re: Giving up on getting this tire to fit.Re: Bob Selby Bob Selby 08/16/19 08:52PM
Want to reply to this thread?
