> P D Wrote:
> I have never had a problem and I'm sure that I've trapped more than just
> a bit of 'moisture' inside the bead .
> The only difference is water will take a bit longer to dissipate , but
> t it does .
> Just for something to think about : why do a lot of shops slop soapy
> water around a rim & tire when mounting ?
> They keep a bottle and rim mop attached to the changing machine .
> Anyway , like I said , I'll keep doing what presents no problems and
> works for me . ;)
Ummm, I worked in more than one shop using a tire changer.
Shops typically dont use "soap and water" unless someone forgets to order more tire bead lube. The bead lube is much slicker than any soap and does not promote rust or corrosion.
Google it, many brands available.
