Re: Giving up on getting this tire to fit.
P D /
> live ɘvil Wrote:
> > P D Wrote:
> > I have never had a problem and I'm sure that I've trapped more than
> just
> > a bit of 'moisture' inside the bead .
> > The only difference is water will take a bit longer to dissipate , but
> > t it does .
> > Just for something to think about : why do a lot of shops slop soapy
> > water around a rim & tire when mounting ?
> > They keep a bottle and rim mop attached to the changing machine .
> > Anyway , like I said , I'll keep doing what presents no problems and
> > works for me . ;)
> Ummm, I worked in more than one shop using a tire changer.
> Shops typically dont use "soap and water" unless someone forgets to
> order more tire bead lube. The bead lube is much slicker than any soap
> and does not promote rust or corrosion.
> Google it, many brands available.
I'm sure that every shop uses bead lube , right ?
I wonder what they used before bead lube was invented ?
Not all shops are created equal .
Anyway , good you got your hands dirty . ;)
  Giving up on getting this tire to fit.Topic by: Tomas Molinari Tomas Molinari 08/11/19 05:34PM
  Re: Giving up on getting this tire to fit.Re: P D P D 08/11/19 06:06PM
  Re: Giving up on getting this tire to fit.Re: Tomas Molinari Tomas Molinari 08/11/19 06:51PM
  Re: Giving up on getting this tire to fit.Re: Den 23 Den 23 08/11/19 06:34PM
  Re: Giving up on getting this tire to fit.Re: Tomas Molinari Tomas Molinari 08/11/19 06:52PM
  Re: Giving up on getting this tire to fit.Re: Tomas Molinari Tomas Molinari 08/11/19 07:30PM
  Re: Giving up on getting this tire to fit.Re: pat splat pat splat 08/11/19 07:33PM
  Re: Giving up on getting this tire to fit.Re: Tomas Molinari Tomas Molinari 08/11/19 07:42PM
  Re: Giving up on getting this tire to fit.Re: live ɘvil live ɘvil 08/12/19 01:23AM
  Re: Giving up on getting this tire to fit.Re: alex . alex . 08/12/19 12:57AM
  Re: Giving up on getting this tire to fit.Re: Den 23 Den 23 08/12/19 06:47AM
  Re: Giving up on getting this tire to fit.Re: live ɘvil live ɘvil 08/12/19 11:43AM
  Re: Giving up on getting this tire to fit.Re: Dirty30 Dillon Dirty30 Dillon 08/12/19 09:53AM
  Re: Giving up on getting this tire to fit.Re: live ɘvil live ɘvil 08/12/19 12:11PM
  Re: Giving up on getting this tire to fit.Re: Monti S Monti S 08/12/19 11:17AM
  Re: Giving up on getting this tire to fit.Re: Trent Anderson Trent Anderson 08/13/19 07:12PM
  Re: Giving up on getting this tire to fit.Re: alex . alex . 08/13/19 07:33PM
  Re: Giving up on getting this tire to fit.Re: Overpriced Parts Overpriced Parts 08/13/19 10:41PM
  Re: Giving up on getting this tire to fit.Re: P D P D 08/14/19 08:21AM
  Re: Giving up on getting this tire to fit.Re: Overpriced Parts Overpriced Parts 08/14/19 12:52PM
  Re: Giving up on getting this tire to fit.Re: Trent Anderson Trent Anderson 08/14/19 01:29PM
  Re: Giving up on getting this tire to fit.Re: Tyler Hautau Tyler Hautau 08/14/19 03:44PM
  Re: Giving up on getting this tire to fit.Re: P D P D 08/14/19 04:12PM
  Re: Giving up on getting this tire to fit.Re: alex . alex . 08/15/19 12:27AM
  Re: Giving up on getting this tire to fit.Re: live ɘvil live ɘvil 08/15/19 03:23AM
  Re: Giving up on getting this tire to fit.Re: P D P D 08/15/19 08:11AM
  Re: Giving up on getting this tire to fit.Re: alex . alex . 08/15/19 01:53PM
  Re: Giving up on getting this tire to fit.Re: P D P D 08/15/19 06:06PM
  Re: Giving up on getting this tire to fit.Re: live ɘvil live ɘvil 08/16/19 12:27AM
  Re: Giving up on getting this tire to fit.Re: P D P D 08/16/19 07:59AM
  Re: Giving up on getting this tire to fit.Re: live ɘvil live ɘvil 08/16/19 06:51PM
  Re: Giving up on getting this tire to fit.Re: P D P D 08/16/19 07:15PM
  Re: Giving up on getting this tire to fit.Re: mark alan mark alan 08/14/19 11:49PM
  Re: Giving up on getting this tire to fit.Re: Richard Eberline Richard Eberline 08/15/19 02:17PM
  Re: Giving up on getting this tire to fit.Re: alex . alex . 08/15/19 06:56PM
  Re: Giving up on getting this tire to fit.Re: Seth B Seth B 08/16/19 08:06PM
  Re: Giving up on getting this tire to fit.Re: Bob Selby Bob Selby 08/16/19 08:52PM
